Help with supercharger oil
Help! I've got my supercharger off so I can replace a failed knock sensor and install my spare set of injectors I just got back from the ultrasonic cleaners. I had planned to do this in 2 evenings and lined up all the parts. But, I forgot to consider the supercharger oil. I don't have time to order the TRD oil kit through the dealer; I need to put this back together tonight. Does anyone have the GM part number that was posted up some time ago regarding a cheaper alternative to the Magnuson oil? ( GM uses the same superchargers)
Also, does anyone have a link to the instructions for changing the oil? Is it exactly 4 ounces?
Will
Will
this should be it:
Part #12345982
each bottle is 4oz. I believe the GM blowers take 8oz total.... most dealers stock it should be about $8-16 each...
hope that helps...
Part #12345982
hope that helps...
On another note, I found the TRD spec sheet that specifies to use 120 ml of S/C oil... 120ml = exactly 4 ounces. I'm grabbing a bottle on the way home at the Chevy dealer
anniesball
07-29-2015 11:46 AM
mengquis
07-13-2015 10:39 AM
