Help! Replacing front bearing on 4Runner - YotaTech Forums
Go Back   >
LinkBack Thread Tools Search this Thread
Old 05-19-2009, 06:02 PM   #1
I have a 97 4runner limited 4x4. I am trying to replace the front wheel bearing. The trouble I am having is finding the part. I have ordered two bearings, one from advance auto parts and one from Toyota. My mechanic says that the bearings are too big to fit. I have attached a photo of the bearing that we are trying to replace.
What is going on? Could there be two bearings? Is my mechanic an idiot? Which side does the bearing slide out from, brake side or axle side? Any help would be appreciated.
bringles is offline   Reply With Quote
Old 05-20-2009, 04:12 AM   #2
GSGALLANT's Avatar
There is only one bearing per side. Once you get the axle hub pressed out, and you remove the bearing spacer and ABS ring, you'll be able to see things more clearly. You'll then need to remove the seal and snap ring on the outboard side of the spindle, then you press the bearing outward (towards where the rotor would be). To install the new bearing, you press it in from rotor side, and re-install the rest of the parts in the reverse order that you took them out.
Are you planning on trying this with the spindle still installed on the vehicle? It's a lot easier with the spindle on a bench, and even much easier if you have access to a press.
GSGALLANT is offline   Reply With Quote
Old 05-20-2009, 08:06 PM   #3
Kerby J's Avatar
there is also a clip inside of the housing tht no parts sheets have on them and they r bout 7 dollars from toyota and if u replace a bearing then u have to get them bc when u pressit out it tears it in halh and cant be reused
Kerby J is offline   Reply With Quote
Void Dwellers 1995 4Runner 4WD SR5 voiddweller 86-95 Trucks & 4Runners (Build-Up Section) 19 05-02-2016 10:10 PM
Changing Front Brake Rotors 2WD Iceman4193 86-95 Trucks & 4Runners 3 06-28-2015 11:30 AM
1997 4runner 2wd Automatic to 4wd Manual - some some help TheManOutside 95.5-2004 Tacomas & 96-2002 4Runners 0 06-18-2015 04:32 PM
I want to remind you all to lock up your Runners, my old one got broken into. Mohamed 95.5-2004 Tacomas & 96-2002 4Runners 8 06-20-2002 11:42 AM
Tags
2001, 4runner, 95, 97, bearing, bearings, center, front, replace, replacing, runner, support, tools, toyota, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
