help!! with rear axle !!
Old 01-24-2004, 02:09 PM
rjm
rjm's Avatar
i put in a 3/8 inch thick shim in the driver's side leaf pack to compensate for the driver side lean,that taco's are know for. i did this at a buddy's house. i got the truck home (my driveway is not level). i did some measurements. on the driver's side, the front of the rear tire is now 3/4 of an inch farther from the front of the wheel well, than the passenger side. i only disconnected the driver side leaf pack when i did the install. i made sure the pin dropped back in the hole, before i put it all back together. what is the problem?? is it because my driver way isn't level and that the body maybe leaning or did i screw something up??
jerusry
10-19-2015 05:28 PM
88sasturbotoy
08-11-2015 01:56 AM
deepmarsh
08-06-2015 03:44 AM
yourrealdad
07-21-2015 11:13 AM
toyoda8488
07-05-2015 10:18 PM
Quick Reply: help!! with rear axle !!
