help!!! problem on check engine light???
Old 11-04-2008, 05:46 PM
siremacking's Avatar
i got a toyota tacoma 96 model with 5vz engine. recently my check engine light turns on. i just change my fuel filter and change oil. what must i check for this check engine light to turn off.
i live here in the philippines.
Old 11-04-2008, 06:31 PM
scuba's Avatar
try reseting the Ecu...(disconnecting the neg battery cable) for about 10 mins.
then see what happens...If it comes back on you going to need a scanner to see the actual problem
sonic concepts
07-01-2015 02:33 PM
rbravo1
06-29-2015 01:34 PM
Alex Bessinger
06-28-2015 10:05 AM
94hiluxZE
06-22-2015 10:42 AM
Mutinebullfrog
06-18-2015 01:36 PM
Quick Reply: help!!! problem on check engine light???
