Help Pick Tires for Tunda Wheels on 4runner!
Old 03-16-2015, 08:04 AM
IDM
IDM's Avatar
Guys I have a manual trans 4wd 98 v6 4runner.
I picked up a set of tundra wheles for it and want to buy tires.
I'd like to get tires that don't throw off my speedo too bad, that don't hurt my gas mileage, that don't make road noise.
I trailor my boat with the 4 runner and want something safe and that gets great traction, especially in the rain.
I would like for them to look a little agressive but without compromising all of the things I mentioned. Should I get something a little taller and/or wider?
What are the proper sizes for the tundra wheels on my 4runner?
Thanks again!
Old 03-16-2015, 12:26 PM
konah's Avatar
I have 265/70 big o Bigfoot tires. Small amount of rubbing at full flex and turn. No lift.
Old 03-16-2015, 03:59 PM
IDM
IDM's Avatar
Thanks anyone else?
Do you have those sizes on tundra wheels on a 4runner?
Old 03-16-2015, 05:05 PM
konah's Avatar
I do. On my profile picture.
Old 03-16-2015, 06:17 PM
IDM
IDM's Avatar
Care to post a picture?
the pic is small in your profile
Thanks
Old 03-16-2015, 06:25 PM
konah's Avatar
Old 03-18-2015, 01:15 PM
IDM
IDM's Avatar
What year 4runner do you have? Wasnt 99 higher than all the other years and the rest are about the same height? Is your speedometer off?
What brand are your (big o Bigfoot tires)?
Thanks for your help here
Old 03-18-2015, 02:11 PM
konah's Avatar
2000 limited. There are places on the web to figure out change in speedo differences. I may be off by a mile or so depending on the speed. The brand is Big O. American made, I think they are made by a well known tire company. I have used and trashed a couple other brands in the high desert of nevada. These are doing well so far. Road noise is not a concern for me, so I can't answer that.
Old 03-18-2015, 02:12 PM
konah's Avatar
99 was higher. I'm trying to convince my wife that that is what I need. Before the rest of the suspension fails.
Old 03-18-2015, 06:38 PM
habanero's Avatar
Uncle.
Old 03-18-2015, 09:16 PM
konah's Avatar
265/70-17.
Old 03-20-2015, 02:26 PM
IDM
IDM's Avatar
Thanks can anyone else chime in on suggested tires?
doing a search as well
Old 03-20-2015, 02:43 PM
IDM
IDM's Avatar
There were only a handful of threads I could find. Most people suggested BFG all terrains and the only other size I saw used was 265/65/17 if you are rubbing with 70 then 65 would probably be a better choice.
How do these sizes translate into what people call 30s or 33s etc?
Old 03-22-2015, 03:06 PM
BlazeRunner's Avatar
I have the BFGs and am considering the general grabber aT2, very similar at a great price. As far as sizing goes, some tires run larger or smaller depending on the model, the BFGs tend to run small. 265/70 was factory size on some models and is considered a 31", 265/75 is generally a 32" and 285/75 a 33". There are of course other combinations. a size converter helps http://tire-size-conversion.com/
you should be able to run a 265/70 with stock suspension if it's not sagging. 265/75 can be done, but you will rub. I have no experience with the tundra wheels I just wanted to pass on tire info. I currently run 265/75's on stock suspension with slight rubbing but not bad, my wheels are spaced out an extra 1" though. good luck and check out those at2's
Old 03-22-2015, 05:24 PM
konah's Avatar
We ran the at2s before the big o tires as stock size. Pretty decent. They seemed to wear uneven tire to tire. They have about 25000 miles on them now.
Old 03-22-2015, 06:30 PM
IDM
IDM's Avatar
Thanks guys what has more road noise the big o tires or bfg ats?
Are these louder than stock street tires?
Old 03-22-2015, 06:42 PM
IDM
IDM's Avatar
I also wonder how far off my speedo would be because of going up to 17s if I maintain the same tire size.
right now I have stock tire sizes on 16s.
Old 03-22-2015, 07:26 PM
konah's Avatar
http://tire-size-conversion.com/speedometer
06-01-2021 01:51 PM
MMA_Alex
25
04-18-2017 05:07 AM
Jnkml
07-06-2015 01:20 PM
CJ94yota
07-03-2015 10:14 PM
Quick Reply: Help Pick Tires for Tunda Wheels on 4runner!
