HELP! part# for amsoil oil filter?
Old 06-10-2003, 04:47 PM
Mossback74's Avatar
Exclamation HELP! part# for amsoil oil filter?
I'm looking for the part number of the amsoil oil filter for 2nd gen 3.0 v6. I remember a thread from a while ago that gives the number on a bigger (2 qt?) filter that also fits the 3.0.
I'll be damned if I cant find that thread.
Thanks in advance
Old 06-10-2003, 05:14 PM
Poul D'eau's Avatar
Here was one by 'leaves and lawns' about a month back:
OEM Size Oil Filters
Toyota: 08922-02011, $4.91 (mini-truck, USA); 90915-YZZB9, (mini-truck, Japan); 90915-YZZB5, $4.91 (Tundra V8)
AC Delco: PF2, PF2217, SPF2, UPF2
Fram: PH3614, DG3614
K&N: HP-2004
Mobil 1: M1-204
Motorcraft: FL-793
NAPA Gold: 1068
Pennziol: PZ-21
Puralator: L10241, PL10241
Wix: 51068
Oversize Oil Filters
Toyota: 15600-41010, $12.33 (superseded by 90915-YZZB5, but still available)
AC Delco: PFL1A, PF2, PF2217, UPF2, SPF2
Fram: PH8A, DG8A, TG8A
K&N: HP-3001
Mobil 1: M1-301
Motorcraft: FL-1A
NAPA Gold: 1515 (made by Wix)
Pennziol: PZ-1 (a Fram filter)
Puralator: L30001, PL30001
Wix: 51515
Sadly it doesn't list the Amsoil filter.
Old 06-10-2003, 05:24 PM
Mossback74's Avatar
Damn. Well I'm still lookin. I just know its here somewhere. Thanks for the info by the way. I may just go with one of those. Those are all for 2nd gen V6?
Old 06-10-2003, 05:31 PM
Easy cheesy buddy!
Go to www.amsoil.com and click on the applications guide. Punch in your make and year and model, and it'll list what you need. I don't have any more on my shelf to look at, and the wife is driving the thing right now...hehe.
Old 06-11-2003, 10:11 AM
Mossback74's Avatar
I got that one. What I'm looking for is a bigger filter. There's an alternate part thats for some domestic passenger car I think. I think I'm getting the 57 or whatever anyway but I kinda want to know the bigger one. Or I could be totally crazy:alien:
Old 06-11-2003, 06:40 PM
4x4CPOSEADOG's Avatar
Posted by Mossback74
You cannot install a bigger or longer amsoil oil filter in a 3.0 V6 engine without the oil filter relocation kit. If you are planning to install the bigger filter in there, it will be too tight because there is not much room between the oil filter and the body frame. I have already tried this and it did not work. The filter leak out due to rubbing cause by the filter against the frame. I went back to OEM filter (90915-YZZB9) because this is the only filter that I know will fit in there. I hope this helps. The amsoil filter that I previously used and leaked out was ASF-34, it was a little longer than the OEM filter.
Noel
Old 06-12-2003, 10:26 AM
If you buy Amsoil's remote filter system, you run HUGE filters that go down to something like 4 microns, that means you have clean oil for freakin' ever. I guess this appeals to fleet trucks who can only change oil every 25000 miles.
I've seen these remote filters at work. The guy dumped a few ounces of INDIA INK in the oil, and turned on the pump. Within a minute or so, the ink was filtered out totally, and the oil was see through again. Amazing! I think the kit is around $100.
This kit is for the oil snob as far as I can see, but it illustrates what Amsoil can do for ya.
I think my filter is a spf34, rings a bell anyway. Good luck!
Eggslinger
06-08-2019 03:32 PM
jasonty
41
12-23-2018 01:00 PM
calderp
Engine Swaps
08-16-2016 05:15 PM
calderp
07-27-2015 09:58 AM
ryerye13
07-14-2015 08:27 AM
Quick Reply: HELP! part# for amsoil oil filter?
