Help! No heat issue, not a basic concern
I have a 1996 4Runner with the 3.4. We bought it a few months ago and it has no heat. We have covered all the basics and they are good. There is no coolant flow to the heater core. you can run the truck with the hoses disconnected and only a little leaks out. The engine was replaced at some point not too long before we got it. Is there possibly an engine gasket that was installed backwards that is blocking the flow? I am not familiar with these engines and any help is greatly appreciated. A friend suggested that possibly the intake gasket is incorrect, but I'm hoping someone hear can give a definite answer. Thanks in advance!
The system has been completely flushed, nothing externally is clogged, not sure if the engine was rebuilt or replaced, but probably replaced with a long block
I bet the level is low or you have a air bubble.
Open the heater valve, take off the radiator cap, warm up.....add missing coolant.
Are you sure the engine is warming up all the way?
Bet way to get air out the cooling system and heater core is to drive the front up on ramps or put it up on jack stands.
Take off the radiator cap and start it up and let it run with the heater on full. Every couple of minutes rev the engine up quickly and that will help jolt the air bubbles out of the system.
Just be sure to keep an eye on the level in the radiator because when that air bubble passes and coolant fills the heater core the radiator can drop a good couple of inches.
I had the same thing happen after I replaced the radiator and t-stat on my 02 runner.
Also be sure to check the heater water valve on the firewall directly in the middle of the firewall above the engine. When you turn on the heater the cable should pull the arm and open the valve. This is a common item to get broken during engine swaps.
FOG
FOG
I have a 92 4runner and the heat stopped working today. The coolant is full, the temp gauge is normal (not over heating) but there was gurgling sound sometimes when I was accelerating.
Any ideas?
Any ideas?
Clogged heater core.
Same
Poncho0206
07-10-2015 06:21 PM
