HELP loud winding noise in instrument panel (Dash) HELLA ANNOYING
Old 11-28-2005, 03:04 PM
mrmojorisinphan's Avatar
HELP:Loud winding noise in instrument panel (Dash) HELLA ANNOYING
Has anyone experienced this?
I think it may be related to my speedometer needle because the needle bounces around a little bit when it occurs. It happens at speeds above 10mls/hr. It sounds mechanical, it's a high pitch winding noise, and it usually occurs when it is cold out. I'm thinking something needs to be lubed....any thoughts???
Old 11-28-2005, 04:31 PM
Lt. Dan's Avatar
Mine did that a few months ago. I ended up pulling the instrument cluster out and sprating some lube down the cable while CAREFULLY driveing around the block.
Worked like a charm.
Old 11-29-2005, 07:49 AM
Cool thanks for the tip! I'll give it a try....
Old 11-29-2005, 06:05 PM
trd90toyota's Avatar
I'll 2nd that. We do that at the dealership.
jasonty
41
12-23-2018 01:00 PM
jashoeuh
11-26-2017 07:01 AM
gary4runner
09-24-2015 12:53 AM
rushw
07-18-2015 01:46 PM
Jake28296
07-12-2015 10:15 PM
Quick Reply: HELP loud winding noise in instrument panel (Dash) HELLA ANNOYING
