Help Just cleaned engine bay and it runs very rough now - Page 2 - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 03-27-2007, 04:55 AM   #26 (permalink)
GSGALLANT's Avatar
You likely don't need to replace anything (unless your plugs and wires are due to be changed anyways). Unplug your spark plug wires, and check for water around the plugs. It happened to me. I had less than 1/8" of water down around one of the plugs on the driver's side, and that was enough to cause it to mis-fire. I got rid of the water using a piece of paper towel to soak it up, then I blew it dry with compressed air, added di-electric grease in all the spark plug boots, and re-installed them. Don't forget to clear the codes, then fire it up.
__________________
2002 4Runner, Auto-A340F, 3.4L, 4.30 Gears
TJM T15 Front Bumper & Warn M8000, 4xInnovation sliders, Sonoran Steel 1.2 Lift, Toytec LCA Skids, Tundra Brake Upgrade (231mm), Extended rear diff breather, Deckplate Mod, Andymod, Dual batt setup with Optima blue top aux battery, Hardwired 1000W inverter, Aux fuse box, Full time power to 12V plugs, Yaesu FT7800R Radio, "4-air" system for airing up/down tires.
2004 Camry LE - stock (and will stay that way)
1993 4Runner has been sold
GSGALLANT is offline
Old 03-27-2007, 05:26 AM   #27 (permalink)
I did the samething on my T-100 a few years ago..It run bad for a few miles and then it took a fe days to run like a champ again..You got water some where it did not belong...
RETRO is offline
Old 03-27-2007, 02:38 PM   #28 (permalink)
twitchee2's Avatar
Send a message via AIM to twitchee2
So i pulled out all the plug coils and there was water on all of them. So i dryed them off and stuck a paper towel down there to the plugs to get anything that was still there. it ran a little better, but still very rough between the 1500-2k rpm range. any other suggestions. My parents are just saying go take it in (its thier car).
__________________
-Eric
2002 SR5 4WD
Goodyear Wrangler Duratrac 265/75/16C
Deck plate + ISR
OME 881/890
Tundra 231mm Brakes - yes they DO fit the stock 5 spoke rims
twitchee2 is offline
Old 03-27-2007, 02:46 PM   #29 (permalink)
twitchee2's Avatar
BTW plugs were replaced 10,000 miles ago. Should i just go ahead and replace them anyway?
__________________
-Eric
2002 SR5 4WD
Deck plate + ISR
OME 881/890
Old 03-27-2007, 02:52 PM   #30 (permalink)
Send a message via AIM to Griffeycom Send a message via MSN to Griffeycom Send a message via Skype™ to Griffeycom
There's probably still water in there, keep some paper towels in there and let them absorb the water for awhile. I did the same thing to my old car and after getting all the water out everything returned to normal.
__________________
1998 4Runner SR5 4x4 Auto, Anthricite Metallic.
Griffeycom is offline
Old 03-27-2007, 02:54 PM   #31 (permalink)
twitchee2's Avatar
just stuff them ok i can do that. should i let it sit overnight?
__________________
-Eric
2002 SR5 4WD
Deck plate + ISR
OME 881/890
Old 03-27-2007, 03:30 PM   #32 (permalink)
ebelen1's Avatar
This happened to me when the detailer blasted the motor w/ disregard. The truck ran horrible and displayed symptoms you described. When we pulled the plugs, it was all gunked up. Changed out the plugs (that I bought from the dealer) and all was well.
__________________
____________
Edwin
1999 SR5 4unner
ebelen1 is offline
Old 03-27-2007, 06:08 PM   #33 (permalink)
twitchee2's Avatar
So went and got some NGKs from kragen today thinking spark plugs were spark plugs, i guess not. I guess im going to have to go to Toyota tomorrow and grab some dual ground plugs. .044 spacing correct?
__________________
-Eric
2002 SR5 4WD
Deck plate + ISR
OME 881/890
Old 03-28-2007, 08:50 AM   #34 (permalink)
Bennito's Avatar
What was the CEL code? (maybe I skipped over it - but it sounds like you went to coils/wires based on feedback not on the CEL data)
__________________
Ben - 97 sr5 - full of win.
Bennito is offline
Old 03-28-2007, 09:21 AM   #35 (permalink)
Tanto's Avatar
.044 is the correct spacing, but you WILL have to regap them.
x2 on the CEL code.
__________________
"Prepare for the worst, hope for the best"
2002 Tacoma Doublecab - "TURTLE TACO" Just a bunch of bling on a truck...
Quote:
Originally Posted by deathrunner
Yeah, and my mom's still mad at you.
Tanto is offline
Old 03-28-2007, 09:22 AM   #36 (permalink)
Elton's Avatar
Send a message via AIM to Elton Send a message via MSN to Elton
i hope you didint use a power washer ? i clean mine just about every month i use garden hose and a leaf blower to get rid of most of the water then let it run for a little while and no problems
__________________
My Truck 98 4runner SR5 3.4L 5spd 4x4 E-Locker Mods
Mom 07 Tundra d-cab limited 5.7L 4x4 auto
sister 92 pickup SR5 X-cab 3.0L 5spd 4x4
Papa 89 Pickup SR5 X-cab 4x4 3.0L 5spd/98 4runner SR5 4x4 auto 3.4L
R.I.P 91 4runner SR5 4x4 3.0L 5spd Totaled 5/13/06 My Wreck
Elton is offline
Old 03-28-2007, 10:27 AM   #37 (permalink)
mt_goat's Avatar
Might try cleaning the MAF. The CEL codes would be a big help.
__________________
~Dale~
93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift front, Alcan springs rear, 33 BFG MT, ARB locked front & rear, 5.29 US Gears, RB 1" Body Lift, 1.5" ball joint spacers, manual hubs, TJM T-17, Warn m8000.
mt_goat is offline
Old 03-28-2007, 12:24 PM   #38 (permalink)
Dry it out the best you can then drive it around..The heat from the engine ill dry the rest out it will take some time but will run better...I did the samething a few years back..Ran like crap could not get past 30mph dried them off and ran rough for a while but dried up and ran like a champ...
RETRO is offline
Old 03-28-2007, 03:47 PM   #39 (permalink)
twitchee2's Avatar
well im installing the new plugs today $3 from the dealer then hope fully its drivable then ill drive it to get codes. Its a PITA to pull the plugs when the socket i have deonst have that little rubber thing in the top
__________________
-Eric
2002 SR5 4WD
Deck plate + ISR
OME 881/890
Old 03-28-2007, 05:10 PM   #40 (permalink)
twitchee2's Avatar
swapped the plugs and its good as new. Thanks guys. No more v8 4gen for me now o well
__________________
-Eric
2002 SR5 4WD
Deck plate + ISR
OME 881/890
Old 06-07-2007, 11:31 AM   #41 (permalink)
Tacotex's Avatar
Lil plug trick
Quote:
You can use a socket to break the plugs loose, then a 10-12" piece of rubber 3/8" fuel line to thread the plugs out/in. You can remove some material around the end of the tube to make the walls thinner and more pliable. I've been using the same piece of tubing since '93 or so. Anti-seize is your friend.
__________________
Pete
'04 Taco TRD SR5 4x4 3.4L 5spd, Donahoe coilovers, custom Alcan springs & Bilstein 5100s, 16x8 steelies, deckplate mod, free alarm mod., 265/75/16 Nitto A/Ts.
'07 4Runner SR5 4WD
'08 Honda S2000 CR
'98 4Runner SR5 3.4L auto, Bilstein HDs, 31x10.50 BFG ATs, airbox elbow mod. 250K+ & going strong. Totaled 3/20/09 (separated ball joint=crash)
Tacotex is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Changed plugs and now it runs rough. Beartracker 95.5-2004 Tacomas & 96-2002 4Runners 24 03-12-2007 12:01 PM
3.0 new engine runs rough Chapman88SR5 86-95 Trucks & 4Runners 1 11-16-2006 09:20 AM
runs rough when warm 3.0 Glina 86-95 Trucks & 4Runners 23 05-23-2006 11:55 PM
engine runs rough in 4th and 5th Blakbat 86-95 Trucks & 4Runners 0 10-06-2005 08:51 PM
94 4 runner runs rough rocknron 95.5-2004 Tacomas & 96-2002 4Runners 10 02-15-2003 12:05 PM
2009 InternetBrands, Inc.
