YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 05-17-2008, 05:54 PM   #1 (permalink)
MadCityRich's Avatar
help installing 5125 shocks
I'm about half way through installing my Sonoran Steel 7.2 lift. Front went OK. Disassembling the rear went OK until I got to the rear shocks. I cut them off and everything is good.
I'm have a real PITA time getting the new shocks mounted up. My box end wrench keeps slipping off the nut and I can barely move to get the allen headed stud to turn. I gave up in disgust this evening (really, I was just hungry).
So - any tips on these? As far as I can tell, there is no option to just turn the shock body, like on the stock shocks.
Thanks!
MadCityRich
__________________
Alright, when I say your name, you say 'here.' And we will assume 'here' is short for 'here I am...rock you like a hurricane. -Ignignokt
MadCityRich is offline
Sponsored Links
To remove this ad, register today!
Old 05-17-2008, 06:11 PM   #2 (permalink)
Thanks!
MadCityRich
I used a 14mil deep socket on a smaller ratchet. A box end wrench doesn't have the right angle to grab the nut as you tighten it down. The deep socket gets it over the edge of that damn mounting 'cup', yet isn't too tall (I figured it would be, but it works). I then had about 30-45 degrees of play to slowly tighten down the crown nut. Sure it takes forever, but it works. Use locktite too....
kmcaprice14 is offline
Old 05-17-2008, 08:02 PM   #3 (permalink)
Doesn't the shaft rotate when you do that? For the Bilstein 5125, there is an allen head socket. It looks like you need to hold one steady and then turn the other (either the allen head in the stud or the nut).
But maybe I'm reading it wrong.
Thanks,
MadCityRich
__________________
Old 05-18-2008, 06:02 PM   #4 (permalink)
JHRRLD's Avatar
Send a message via AIM to JHRRLD Send a message via Yahoo to JHRRLD
Installed this kit about a month ago. What I did was used a 1/2 inch ratchet with a 14mm socket and was able to turn the top nut just fine. Loctite is not necassary as the nuts are the nylon lock type. I used a small version of vise grips and a rag to keep the shock shaft from turning. This was the only way I could tighten the top nut.
__________________
2000 4WD 4Runner Sport, auto, 5VZ, SC, URD fuel kit, 2.2" pulley, 4" deckplate, Trueflow filter, Airraid mini intake, TRD Exhaust, trans cooler, IPT Valve Body, TrueTrac rear, SS 7.2, 285 75R 16 BFG ATs on PC'd LX450 wheels, JAOS color matched Spoiler, Line-X'd stubbs sliders
07 Kawasaki Brute Force 750i, stock for now
JHRRLD is offline
Old 05-18-2008, 07:17 PM   #5 (permalink)
I made it work. I have a 17mm wrench from my BMW car tool set that has a steep angle. That held the nut in place. Then I turned the allen headed shaft with my stubby socket + allen socket.
MadCityRich
__________________
Old 05-18-2008, 08:09 PM   #6 (permalink)
seanz0rz's Avatar
Send a message via AIM to seanz0rz Send a message via MSN to seanz0rz
worst design ever. i did an install a week ago and my hands still hurt from it.
__________________
1998 Toyota 4Runner SR5 V6 4x4 in Evergreen Pearl Metallic, Sonoran Steel #1, 285/75R16 BFG A/T, Elocker retrofit, Tundra calipers, brembo blanks, hawk lts pads, CarPC in custom center console with molded Indash touchscreen, KC daylighters mounted on Surco Safari rack, Custom sound system, 4xinnovation sliders, sleeping platform, Shrockworks front bumper, etc.
Pictures
Photobucket is being updated, if a picture i posted no longer works, please PM me.
seanz0rz is offline
Old 05-18-2008, 08:53 PM   #7 (permalink)
Serious pain in the ass, what I did was put an open ended wrench on top and and a strap wrench on the shock body.
yarosig is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Bilstein 5125 shocks muddymile 95.5-2004 Tacomas & 96-2002 4Runners 17 04-18-2008 08:57 AM
FS: Bilstein 5125 Shocks frazier2209 Axles/Suspensions/Tires/Wheels 1 03-18-2008 07:09 PM
Bilstein 5125 Off Road Shocks (Pair) For Toyota Tacoma - $100 dantheyotaman Axles/Suspensions/Tires/Wheels 0 12-13-2006 03:38 PM
Bilstein 10" travel shocks 5125 Arsenal Axles/Suspensions/Tires/Wheels 7 04-20-2006 06:11 AM
While installing shocks, what else should get done Bennito 95.5-2004 Tacomas & 96-2002 4Runners 3 09-20-2004 01:34 PM
Advertise on YotaTech.com
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
