Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
help installing 5125 shocks
I'm about half way through installing my Sonoran Steel 7.2 lift. Front went OK. Disassembling the rear went OK until I got to the rear shocks. I cut them off and everything is good.
I'm have a real PITA time getting the new shocks mounted up. My box end wrench keeps slipping off the nut and I can barely move to get the allen headed stud to turn. I gave up in disgust this evening (really, I was just hungry). So - any tips on these? As far as I can tell, there is no option to just turn the shock body, like on the stock shocks. Thanks! MadCityRich
__________________
Alright, when I say your name, you say 'here.' And we will assume 'here' is short for 'here I am...rock you like a hurricane. -Ignignokt |
| Sponsored Links |
#2 (permalink) | |
Quote:
#3 (permalink) |
Doesn't the shaft rotate when you do that? For the Bilstein 5125, there is an allen head socket. It looks like you need to hold one steady and then turn the other (either the allen head in the stud or the nut).
But maybe I'm reading it wrong. Thanks, MadCityRich
__________________
#4 (permalink) |
Installed this kit about a month ago. What I did was used a 1/2 inch ratchet with a 14mm socket and was able to turn the top nut just fine. Loctite is not necassary as the nuts are the nylon lock type. I used a small version of vise grips and a rag to keep the shock shaft from turning. This was the only way I could tighten the top nut.
__________________
2000 4WD 4Runner Sport, auto, 5VZ, SC, URD fuel kit, 2.2" pulley, 4" deckplate, Trueflow filter, Airraid mini intake, TRD Exhaust, trans cooler, IPT Valve Body, TrueTrac rear, SS 7.2, 285 75R 16 BFG ATs on PC'd LX450 wheels, JAOS color matched Spoiler, Line-X'd stubbs sliders 07 Kawasaki Brute Force 750i, stock for now Last edited by JHRRLD : 05-19-2008 at 05:53 AM. |
#5 (permalink) |
I made it work. I have a 17mm wrench from my BMW car tool set that has a steep angle. That held the nut in place. Then I turned the allen headed shaft with my stubby socket + allen socket.
MadCityRich
__________________
#6 (permalink) |
worst design ever. i did an install a week ago and my hands still hurt from it.
__________________
1998 Toyota 4Runner SR5 V6 4x4 in Evergreen Pearl Metallic, Sonoran Steel #1, 285/75R16 BFG A/T, Elocker retrofit, Tundra calipers, brembo blanks, hawk lts pads, CarPC in custom center console with molded Indash touchscreen, KC daylighters mounted on Surco Safari rack, Custom sound system, 4xinnovation sliders, sleeping platform, Shrockworks front bumper, etc. Pictures Photobucket is being updated, if a picture i posted no longer works, please PM me. |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Bilstein 5125 shocks | muddymile | 95.5-2004 Tacomas & 96-2002 4Runners | 17 | 04-18-2008 08:57 AM |
| FS: Bilstein 5125 Shocks | frazier2209 | Axles/Suspensions/Tires/Wheels | 1 | 03-18-2008 07:09 PM |
| Bilstein 5125 Off Road Shocks (Pair) For Toyota Tacoma - $100 | dantheyotaman | Axles/Suspensions/Tires/Wheels | 0 | 12-13-2006 03:38 PM |
| Bilstein 10" travel shocks 5125 | Arsenal | Axles/Suspensions/Tires/Wheels | 7 | 04-20-2006 06:11 AM |
| While installing shocks, what else should get done | Bennito | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 09-20-2004 01:34 PM |
