Help I need a wiring diagram for the 4wd circuit on a 1997 4runner
So the title says most of it. I have a 1997 4runner base manual trans with the j shifter.
I ran into my 4wd not working the other day. Below is what I have found so far.
I have traced down the wire that is not going to ground from the add relay and need the wiring diagram to see where it goes. I replaced the transfer case switch today and still had nothing engaging unless i either switch the vacuum hoses from the vsvs around or I can manually trigger the wire on the relay and all is good. I believe it is a green with red stripe wire.
Thanks in advance
Thanks in advance
Thanks in advance
Thanks in advance
97 4Runner 4WD w/o 2-4 select switch (i.e. with the J-pattern shifter) EWD.
And FWIW, $15 and a couple hours of downloading pdf's from http://techinfo.toyota.com/ is 100% worth the time and money.
Thank you for the diagram! I ended up reading a tiny comment in another post that lead me to investigate a plug at the top of the transmission that wasnt connected. I took the shifter plate out of the vehicle to see where it would plug in and wouldnt you know it another connector on the top passenger side of the tranny was disconnected. I plugged that in and it started working.
Now just to verify I only saw 1 position indicator switch on my transfer case is this correct? I traced everywhere on the unit and only found 2 wires going down and they went to 1 indicator.
Any idea what the other non connected wire harness is for on the top of the tranny on the drivers side?
With the M/T you should have 2 plugs on your transfer case for 4wd (plus one for the vehicle speed sensor, this will be near the back of the case just in front of where the rear drive shaft attaches). The 2 4wd plugs are:
- D3 DETECTION SW (TRANSFER 4WD POSITION). This determines whether the transfer case is in 2WD or 4WD, regardless of high vs low, and is used by the ADD circuit to activate the VSVs and illuminate the 4WD light on the dash.
- D5 DETECTION SW (TRANSFER L4 POSITION). This determines whether the transfer case is in the High or Low range, and is used by the ECU, 4wd computer, ABS control unit, and the rear diff lock control unit (if equipped).
Thanks again for all the help! We got freezing rain and about 4-5 inches of snow yesterday and the 4wd works like a charm now. In fact much better than expected.
06-01-2021 01:51 PM
Jnkml
07-06-2015 01:20 PM
