Help! I did something stupid... Break Lights/Shifter problem
Old 01-21-2009, 04:01 PM
98SR54RUNNER's Avatar
Help! I did something stupid... Brake Lights/Shifter problem
So like many others I got the LED tails and 3rd light.
When I was attempting to install the LED brake light, the wires touched, sparked and I think effed something up.
Now my break lights dont work and my shifter is stuck in park.
I have checked fuses, I don't see any broken. I need a solution to this.
I have read that this is some kind of shifter solenoid. I need my car for class and work. PLEASE HELP ASAP ! THANKS!
Old 01-21-2009, 04:19 PM
97ltd4x4's Avatar
3 fuses to check:
10A stop
15A ACC
10A ECU-IG
In case you cannot figure it out..you can bypass the shifter lock,by prying up the little shifter cover(little black cover forward of the shifter),and then depressing it with a screwdriver or pen,ect(white plastic piece under the cover)
Old 01-21-2009, 04:22 PM
darksoldier313's Avatar
dont visually inspect the fuses check the continuity of them and check to c if there is voltage on both sides of the fuse
Old 01-21-2009, 04:33 PM
Originally Posted by 97ltd4x4
3 fuses to check:
10A stop
15A ACC
10A ECU-IG
I will check these fuses again. I do not have a voltmeter...should I go get one at walmart or something to check continuity?
I tried to bypass the lock, it still wont move. Maybe I'm not pushing hard enough on the little white thing.
Thanks for the swift replies, I need to get my car working tonight for work and school tomorrow!
Old 01-21-2009, 04:43 PM
Yeah, I can't get it out of park at all. Even after pushing on the manual release, it won't move.
It's like the manual release is locked down.
Old 01-21-2009, 04:45 PM
if u dont have a test light or dmm replace the fuses labeled above with one of equal rating c if that works and if u push on the manual shift lock overide and it doesnt shift u have issues unless your not doing it right h/o ill look it up
Old 01-21-2009, 04:55 PM
I don't think I'm not doing it right because I have used it before when installing other electronics.
How could such a serious problem arise just from attempting to install a damn brake light?
I'm going to get new fuses and a voltmeter now. Thank for your help.
little side note disconnect the battery when doing that kind of work if u can get ahold of dmm i can give u some wiring diagrams to help and a voltage chart should help in the diagnosis period another quick test bypass the brake light switch c if that works after u have properly checked the fuses
Old 01-21-2009, 04:57 PM
I'm getting new fuses and a tester now. I will update on what happens. How would I bypass the switch?
Not really even sure what to check once I have the meter. Ill be back in a few, thanks again.
Old 01-21-2009, 05:01 PM
depends on how many wire switch it is if its two u just jump them together once u get the dmm u can pull the fuses out check for resistance in the ohm function if it says 0 your good if not its bad once u do that we will get into the more complicated tests
Old 01-21-2009, 05:30 PM
Got the DMM. Now I should be checkign for 12v across these fuses right? And 0 ohms. I'm going to do this now, and replacing them all.
Old 01-21-2009, 05:44 PM
dont check the resistance with the fuses still plugged in
Old 01-21-2009, 08:10 PM
Finally got it!!!! I feel stupid, but finally found that it was a fuse.
I replaced all the interior, and several under the hood and still nothing.
And then I checked resistance and all was good, and then I took apart the shifter area trying to locate the brake switch solenoid.
Then I checked the fuses again and found............................................. ........
I must have picked up an old fuse or one of the new ones was bad, but I replaced the three main fuses again, and bam im in reverse!
Thank you very much for your help! I'm glad to have my car back...and some new lights!
Old 01-21-2009, 08:14 PM
glad to hear your running again learn ne thing from this experience??
Old 01-22-2009, 06:48 AM
Hah. Don't be lazy and disconnect the battery before any electrical work. Thanks again for your help!
Old 01-22-2009, 09:20 AM
yep no problem glad it was something easy could have been alot worse
calderp
Engine Swaps
08-16-2016 05:15 PM
calderp
07-27-2015 09:58 AM
CanRunner
07-20-2015 01:29 PM
kvanzandt1
07-18-2015 10:15 AM
colasurdo
07-16-2015 11:37 AM
Quick Reply: Help! I did something stupid... Break Lights/Shifter problem
