Help! I can't change my #6 spark plug (can't get to it)
Old 12-05-2016, 08:06 AM
mjninc's Avatar
I can't get to the #6 plug. The wrench won't fit in between the metal thing not sure what it is(?). How should I proceed? Thanks for your help!
# 6 Spark Plug, Drivers side, by the firewall. View #2, from the top of the engine.
Old 12-05-2016, 01:02 PM
83's Avatar
Can you get a swivel attachment in there with an extension?
I did my plugs, tubes and wires when I replaced my valve cover gaskets (looks like yours could use them too, if you're looking for another project ), so I didn't have to deal with this. Everything was out of the way. I'm sure with an extension and swivel you'd be able to get at it, though.
Makes it a little easier
Marc's Avatar
Can you move metal thing?
May have to remove or loosen a bolt.
Old 12-05-2016, 03:44 PM
mjninc's Avatar
I ended up not needing to move it. A long extension with a 5/8 spark plug socket could sneak to the right of it. Thanks Marc!
Old 12-06-2016, 12:12 AM
wyoming9's Avatar
Red face
When I change my plug I remove the top bolt and loosen the bottom one on the bracket and just move it towards the front. of the engine.
Not like your changing plugs all that often
Old 12-06-2016, 04:34 AM
aowRS's Avatar
Thats what I've always done as well.
Andreas
