Help!!!! I broke off 2 wheel studs
Ok so im changing out my IFS worn out tires for some other tires i have and i get the fronts off just fine. I get the back left off just fine... i get to the back right they are hard as hell to turn.. so i stand on the braker bar to getr better leverage one comes off ok.. then i break one and think it cant happen again ... so be as smart as i am i decided id try and get the other ones off.. and there broke stud number two . Am I screwed? Or can i pull something off a truck in a wrecking yard to replace the whatever it is with ( im not sure what the studs are attached too... maybe the brake drums or the axles i guess...) and can i still drive the truck with 4 good wheel studs?. Quick Help me please.
thanks,
Andy
thanks,
Andy
I had the same thing happen to me. All you have to do is take off the drum and then tap the broken stud out. I got a couple new studs from my Toyota dealership. They have little ridges and a cap at one end. The ridges are what holds it in the hole. It was hard to get it the whole way in so I put the drum and wheel back on and tightened the lugnut down on it to get it seated the whole way. Hope this helps.
Originally Posted by Intrepid
I usually try to put a little anti-seize on them to keep them from freezing on like that.
Originally Posted by 88yotaboy
I didnt tighten them on like that... the guy at the tire shop did it when he rotated the tires...
i called my local napa auto parts store and my budy their ordered some up for me... $2.95 each. So im going to try and just tighten the new ones on like some of you said you've done in the past... maybe ill do a right up on this . hmm. Thanks for all the info everyone.
I just use plain dino oil to keep them from sticking like that. Old trick my Dad pushed on me.
But I also graps his ear lobe when he burns his fingers tips thinking that it helps and lessens the burn. But he has stopped putting butter on burns.
So who knows
So who knows
Originally Posted by jimabena74
actually you are not supposed to put oil onto the threads of anything threaded......
$6 and 1 hour later the old studs are out the new ones are in and i must say that was pretty easy.
I did the whole thing with the things in place i just used a punch and a hammer to pound of the old ones and i used a lugnut to tighten the new ones into their places.
06-01-2021 01:51 PM
whereAreMyPants
07-22-2015 03:32 AM
sabine
07-18-2015 03:59 PM
