Help Help Help Quick
Old 09-02-2004, 02:13 PM
4Hummer's Avatar
WHats the secert to remove the cone washers on the front hub of the axle ?
Im trying to remove my busted CV Shaft right now.
Oh I have ADD if that makes a dif
Old 09-02-2004, 02:19 PM
4Hummer's Avatar
heres a pic. a bad one but a pic
http://www.mudrunner.ca/other/hub.jpg
Edit:
HUGE pic, now linked.
Old 09-02-2004, 02:21 PM
4Hummer's Avatar
bump. bump
Old 09-02-2004, 02:33 PM
4Hummer's Avatar
Never Mind GUYS. Like most things in life BASH It with a BFH and they pop out,
THANKS ANYWAY
Old 09-02-2004, 03:14 PM
BeaterToyota's Avatar
THANKS ANYWAY
That is exactly what I was about to recommend.
Old 09-02-2004, 03:21 PM
Flamedx4's Avatar
yup, thats what I did, actually I tap a screwdriver with a hammer against them not too harshly and they pop out.
Old 09-02-2004, 06:56 PM
Albuquerque Jim's Avatar
Brass hammer, yes I have them on a 3rd gen
Old 09-02-2004, 07:01 PM
Robinhood150's Avatar
Your best bet for quick answers is to try a search.
Old 09-02-2004, 07:11 PM
Co-Founder/Administrator
Staff
Corey's Avatar
The brass hammer should also be mentioned in the Tech write-ups in the Tech section for hubs.
Although I find Maxwell's silver hammer works even better.
Old 09-02-2004, 07:28 PM
Cebby's Avatar
Or you can leave the nuts on the end of the studs and whack them right on the end with a hammer...
Old 09-02-2004, 07:30 PM
Cebby's Avatar
Or you can use one of these...
Old 09-03-2004, 08:58 AM
Flamedx4's Avatar
That's pretty. What is it?
Old 09-03-2004, 09:53 AM
Cebby's Avatar
Hub puller.
Remove the dial, screw this unit in place of the dial and tighten the big bolt in the center. I gently pulls the hub body off the studs - bringing the cone washers with it.
Old 09-09-2004, 02:35 AM
ohioyotaguy's Avatar
where can I get that hub puller? I need it ASAP
kawazx636
10-06-2021 03:03 PM
ladybugRC
458
08-21-2020 10:41 AM
zytra
01-24-2019 03:16 PM
charlie_fong
09-27-2015 10:06 PM
Quick Reply: Help Help Help Quick
