help....energy bushings
Old 07-04-2005, 06:20 PM
Localmotion's Avatar
Does anyone know if u can reuse the bracket for the energy suspension front sway bar bushings? THanks
Old 07-04-2005, 07:06 PM
FilthyRich's Avatar
if the bushing did not come with a new bracket, then YES. Are they the ones with zerk.grease fittings???
Old 07-04-2005, 07:41 PM
no they dont have zerk fittings. I have searched and found various p/ns for the front sway bar. Im wondering if I got the wrong ones
Old 07-04-2005, 08:48 PM
this is my part number 8.5118G. The brackets are too small and i did not get any bolts for them. Does anyone know where i can just order the bracket? Im thinking about just ordering a new kit. Do i go with energy or daystar? I need something fast though...i dont have anything to drive.
Are the ones from wheelers any good compared to the energy ones. the energy ones have graphite? in them. does it matter? tHanks again
matt
Old 07-04-2005, 11:15 PM
midiwall's Avatar
If you're talking about using a stock bracket to support the ES bushings, no, you can't (at least I can't). The ES bushing are much thicker in terms of outside diameter and the stock brackets simply won't work.
You can drive without the front swaybar... You'll wanna be careful about pulling corners, but you won't break anything on the truck.
Old 07-05-2005, 07:04 AM
do you know where i can just get the support brackets for the ES bushings?
Thanks
Old 07-05-2005, 09:10 AM
Thanks
I found these part numbers---I do not have an addeco swaybar.
Fronts -- http://store.summitracing.com/defaul...161R&x=21&y=11
rear-- http://store.summitracing.com/defaul...156R&x=21&y=11
are these right? Also, I already have the NON greasable front sway bar bushings, just no brackets. is there anywere i can get brackets???
Old 07-05-2005, 09:27 AM
The bushings say they are for a 25mm front sway bar and the rears are for a 19mm sway bar. Is that right?
Old 07-05-2005, 10:11 AM
midiwall's Avatar
Have you tried contacting ES?
http://www.energysuspension.com/pages/toyt1.html
Old 07-05-2005, 10:13 AM
Originally Posted by midiwall
yea i did. they didnt really help me. Just told me to refer to thier catalog.
Old 07-05-2005, 11:03 AM
photomike72's Avatar
Contact Cebby here on the board. He helped me out with some. DK if you can reuse the brackets.
Mike
Old 07-05-2005, 12:21 PM
midiwall's Avatar
Damn... that sucks.
ummm, I'm also not sure of the sizes. I went through all of my parts orders for the truck from various vendors in the last 2 years and I couldn't find any reference to them.
I dunno if the ones that you found at Summit are right... The chart at ES seems to say 19 & 23, and then I found this site:
http://www.carjunky.com/accessories/...n&skipped=true
Which is saying 27mm for the front - that seems HUGE.
Old 07-05-2005, 12:55 PM
well i took a caliper and did a quasi mesaurment and got 26mm. Damn...i just want to order some gresable bushings for my stock sway bar :cry:
Old 07-06-2005, 07:42 AM
i guess im just gonna order the 1" sway bar bushing and the 3/4 for the rear
Old 07-06-2005, 09:05 AM
2000t4r's Avatar
I have been wondering this as well. While I have searched this site for a while I always seem to get different sizes on bushings to order.
Old 07-06-2005, 12:41 PM
i just went ahead and ordered the 1" bushing for the front and the 3/4 for the rear. Ill let you know if they fit properly.
Old 07-08-2005, 03:29 PM
alright..heres the verdict.
Energy Suspensions greasable bushings are amazing. Day and night difference
The factory sway bar upfront is 1inch and the rear is 3/4. The only thing is that i had to buy new bolts and diff washers b/c the washers that came with the bushings are trash. Also, you might want to order new bushings for the endlinks.
Old 07-13-2005, 11:52 AM
2000t4r's Avatar
Thanks Localmotion do you happen to have the part numbers for the geaseable bushing? Also what about the part number for the endlinks?
Old 07-13-2005, 02:48 PM
Crux's Avatar
Dang, no wonder it was so difficult to get that bracket back on after installing the ES bushing.
I had to use a floor jack to press the swaybar bracket back on over the new bushings and then cranked the bolts down, lol.
(I used the 26mm bushings for my 97 4Runner btw).
Old 07-13-2005, 05:37 PM
midiwall's Avatar
yeah... That little tidbit caused some new words to show up under my truck one day.
I first "realized" it in a thread here talking about rack bushings.
Quick Reply: help....energy bushings
