Help with DRL Disable mod...
Old 10-31-2004, 05:48 AM
Gangus2006's Avatar
I wanted to disable my DRLs, so I red the tech article on YotaTech.
BUT I cant seem to find this module right here.
"Now those instructions are ok, but was vague for me.... But ok... time to look for
the Main Relay... under the dash on my 2001 Drivers side above the gas pedal
there was a box that looked like this: "
I looked there but couldnt find it. Is it in a different spot int he 2000?
Gangus2006 is offline
Old 10-31-2004, 08:34 AM
AZ4ME's Avatar
For a 2000, the DRL box is in the engine bay on the DS fender wall right beside the battery. It's a small black box with vented slits all over it. Unplug that box and no more DRL.
AZ4ME is offline
Old 10-31-2004, 08:47 AM
Masato's Avatar
On my 99 Tacoma, it's also in the engine bay beside the battery. I installed a kill switch on mine so that I have the option of turning them on or off from inside the cab. I usually keep them on but if I go out hunting, I turn them off. Its quite an easy mod if your DRL box is located in the engine bay. Its just a matter of wiring up a rocker switch to the negative (I think) side. I used an OEM rocker I bought from the dealer though any switch will work. On my switch (which had three prongs and an amber light) the prong opposite the light (top or bottom depending on which way you have the switch oriented) gets grounded. Then is just a matter of running a piece of wire with male or female disconnects back to the DRL harness. I don't like cutting factory wires so what I did was I unplugged the DRLs, and then connected male and female disconnect terminals to the factory plugs thereby eliminating the need to cut the factory wires. Its an extra step, I Know but like I said, I hate cutting factory wires up. So that takes care of connecting a switch to one side of the terminal. For the other side (you will notice that there are two wires going to the DRL plugs), I just took a short piece of wire with two disconnects and basically made a jumper and connected the other wire back up. I wrapped everything with split flex tubing and now its looks very clean and works.
Masato is offline
Old 10-31-2004, 11:51 AM
Gangus2006's Avatar
So I dont have to cut a wire like the uttorial says? I just unplug it and Im set? Will my headlamps work?
Old 10-31-2004, 03:03 PM
kevin444's Avatar
Nope i have 2000 4runenr myself. Just unplug it from the socket. Its next to battery looks like it has a metal cage around it.
kevin444 is offline
Old 10-31-2004, 08:41 PM
AZ4ME's Avatar
Yep, just unplug it. Headlights will work like normal (minus DRL's). The writeup in the tech section is just for the 01-02's.
AZ4ME is offline
Old 11-01-2004, 12:41 PM
Gangus2006's Avatar
so is this it? I dont want to unplug something then have the headlights crap out while im cruising down a back road somewhere...
Old 11-01-2004, 12:42 PM
Gangus2006's Avatar
Dd I do anything with those connectors or do I just leave them? Should I seal them up somehow?
Old 11-03-2004, 01:44 PM
Gangus2006's Avatar
BuMp!
Old 11-03-2004, 02:25 PM
AZ4ME's Avatar
That's the box. I just unplugged it over a year ago and have had no issues with my headlights (other that the DRL don't work ). You can tie up the lose connector if you wish.
AZ4ME is offline
Old 11-03-2004, 06:47 PM
Rick F.'s Avatar
Location: Far western Kentucky (transplanted from central PA)
Correct. That's the connector to unplug. Everything works as normal, just no DRL's.
Rick F. is offline
Old 10-21-2007, 11:52 AM
02Surf SSR-X 4xSport's Avatar
https://www.yotatech.com/forums/f127...96/#post917477
02Surf SSR-X 4xSport is offline
Old 01-06-2008, 09:30 AM
plm7878's Avatar
I want to thank you all. I just bought a 98 4Runner limited and I just went outside and disconnected the plug next to the battery and my DRL's are off now. Thank You for the great info..
plm7878 is offline
Old 05-06-2008, 12:30 AM
-T4R175-'s Avatar
I want to thank you all as well I have an 00 runner and hate my drl's. I live in the suburbs in southern California and the only close off roading is illegal so being able to turn your lights off is a must. Thanks so much.
-T4R175- is offline
theking11863
03-19-2016 09:36 PM
JamesDINAN
09-22-2015 05:37 AM
Tennesseestorm
09-12-2015 01:37 AM
jmyer72
08-20-2015 07:55 AM
JGage
52
06-04-2003 07:17 AM
Quick Reply: Help with DRL Disable mod...
