Sign in using an external account
| 95.5-2004 Tacomas & 96-2002 4Runners 4th gen pickups and 3rd gen 4Runners |
| Welcome to Yotatech! |
LinkBack | Thread Tools | Search this Thread |
#1 (permalink) | ||||
Personal
Sales Rating: (0)
Help! Check engine light after type "O" mod
__________________
*99 Desert Dune SR5 4WD 5spd, Extended diff breathers, Deck plate mod. Bilstein Shocks, Hella 500 fog lights mounted on TJM T-15, Stubbs sliders, Type "O" Throttle body gasket, Optima Redtop, ARB RD23 rear locker and air compressor, Shackle hangers, Custom catback exhaust with Magnaflow muffler. |
#2 (permalink) |
Away
Personal
Sales Rating: (0)
You have a vacuum leak. Check for proper orientation of the gasket, it only fits one way correctly. Check for proper torque of the bolts and nuts that hold the TB to the manifold.
Hope this helps. G |
#3 (permalink) |
Personal
Sales Rating: (0)
[OP]
Thanks a lot.
George
__________________
#4 (permalink) |
Personal
Sales Rating: (0)
Yep, what he said.
Definately a vacum leak there or wrong gasket orientation.
__________________
- Jamie 1996 4Runner SR5 4X4 Auto Deckplate Mod, Hayden Tranny Cooler, Amsoil Air Filter, OME 881/906 N86C/N91SC Lift Best OBD II scan tool I have used!. .....and I am AMERICAN! |
#5 (permalink) |
Personal
Sales Rating: (0)
So should the gasket just go straight on? Or should I try to help the seal with something - kind of like how you use the motor oil on the oil filter before you screw it on?
#6 (permalink) |
Personal
Sales Rating: (0)
[OP]
The problem's solved. It was a vacuum leak due to one hose underneath the throttle body not being connected. I didn't see it when i reinstalled because it was directly underneath and i didn't disconnect it on purpose. It was disconnected when i was pulling out the throttle body. Here is a pic of the culprit.
Again, thanks a lot for all your help. Yotatech rocks!!!! George
__________________
#7 (permalink) |
Personal
Sales Rating: (0)
when i installed the O gasket my rpm's jumped about 500, and from past experiences with making my truck idle higher i got a check engine light , the high idle tripped a sensor and threw a CEL. when i installed my O gasket i just adjusted the throttle cable to lower my idle.
__________________
=Jason= 2001 Tacoma DC PreReunner SR5 (looks stock to me) S/C and some other crap |
#8 (permalink) | |
Sponsoring Member
Vendor
Sales Rating: (0)
Quote:
![]() Once on my truck when I installed a trottle body adapter two years ago (and didn't find it until Dr. Z spotted it in a picture - ALMOST A YEAR LATER!). Then it happened again - this time by accident - when I installed an O gasket on FunRunner's truck.
__________________
~ Mark '96 4Runner Limited S/C MI - 370cc injectors, Air! horns, Airaid MIT, ATS A-arms, 285/75/R16 BFG MTs, Bored TB, Brembo slotted, Cobra 75 WXST, Deckplate, Downey headers, Hayden cooler, IPT valve body, Level 10 torque convertor, Meanstreak exhaust, OME/OME rears, On-board PC (XM, Nav, WiFi, etc), Port 'n Polish, Remote Start, SAW fronts, Hilux console, SMT-5, Stubb's sliders, Supra MAF, TJM-17, 2.0" pulley, Viair 450c, Walbro 190, Weasy2k cams |
#9 (permalink) | |
Personal
Sales Rating: (0)
Quote:
![]() ahhh.... so the first time you were just testing Dr. Z, right?
#10 (permalink) | |
Sponsoring Member
Vendor
Sales Rating: (0)
Quote:
__________________
| Tags |
| body, check, engine, gasket, light, modification, throttle, wrong |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Question on "Type R" Diff Breather Mod | MillerPKA | 95.5-2004 Tacomas & 96-2002 4Runners | 25 | 07-19-2007 03:05 AM |
| Check engine light - P0340 (Camshaft position Sensor "A") | Bay Runner | 95.5-2004 Tacomas & 96-2002 4Runners | 2 | 07-25-2006 02:42 PM |
| 1995 tacoma "check engine light" | 95 Ttac | 95.5-2004 Tacomas & 96-2002 4Runners | 4 | 10-04-2004 11:40 AM |
| How can I check the "check engine light" codes on a '00 4Runner? | goldtaco9 | 95.5-2004 Tacomas & 96-2002 4Runners | 7 | 06-12-2004 05:28 PM |
