help cant get truck to start
Old 02-16-2005, 10:37 PM
orfieldg's Avatar
i have a 1986 toyta 4x4 with a 22r and a 5 speed ilove playing in this old truck. but i had a timing chain break last week and now i cant get it to start can anyone help?
i have checked the timing over&over its right, i've checked fuel its ok, i've checked the spark its ok, but still no start can anyone help?
Old 02-16-2005, 10:46 PM
02SE's Avatar
Are you sure the timing isn't off 180 degrees?.
Old 02-16-2005, 10:51 PM
orfieldg's Avatar
i'm sure
Old 02-16-2005, 11:01 PM
the_supernerd's Avatar
Was it the guides or chain that broke? If the chain broke then your valves are probably damaged because the 22R is an interference engine.
Old 02-16-2005, 11:17 PM
orfieldg's Avatar
it was the chain and the cam gear and the guides i dont know what gave out first but had to replace all
Old 02-16-2005, 11:21 PM
Try doing a compression test. Some of your valves are probably bent.
Old 02-16-2005, 11:24 PM
jimbo74's Avatar
if you got lucky and they are not bent, you still might have issues with being off on the timing.. bear in mind that the distributor can be 180* off and this will not allow it to start.. the engine timing can also be 180* off and this will also not allow starting
orfieldg's Avatar
thanks will do.
but i don't know what the compression is?
Old 02-16-2005, 11:27 PM
jimbo74's Avatar
you dont know what engine compression is?
Old 02-16-2005, 11:39 PM
To do a compression test, screw the compression tester into a spark plug hole, disconnect the coil wire, and quickly crank the engine. Read the tester and check the compression on the next cylinder. I think the 22R should be about 170.
Old 02-16-2005, 11:40 PM
orfieldg's Avatar
no not when i check the compression with a compression gauge.
Old 02-16-2005, 11:41 PM
orfieldg's Avatar
ok will do thanks alot
Old 02-16-2005, 11:55 PM
jimbo74's Avatar
if you are pretty close to 170 like say all 4 are @ 130 then thats still ok..... if they are all around that... there shouldnt be anything going on like 134, 145,142, and 85 ... that would be a bad thing
Jdgarrison
10-01-2015 05:22 PM
Badger62811
06-26-2015 09:26 PM
slider417
06-22-2015 10:18 AM
jmc88runner
06-18-2015 03:39 PM
Quick Reply: help cant get truck to start
