Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
help!! bleeder valve is stuck
i am pressure bleeding my 99 4runner sr5 right now and I could not get the bleeder valve to open......I put a little PB blaster on it and decided to ask the forum while I wait for it to penetrate......I am turning the valve counter clockwise but i am afraid I might over torque and break the thing.
Eric
__________________
99 4runner SR5 V6, Mako wheels by Ultra 16", eclipses headunit, eclipse amp, 10" JL Audio with Bandpass Sub box, eclipse separates front and eclipse 2 way rear. |
| Sponsored Links |
#2 (permalink) |
Those bleeder valves are also made of weak metal. Definetly get a 6-point (not 12-point) socket on that sucker (10mm). I would use a short breaker bar, and get that leverage to turn very slowly. PB blast it for a little.
Also, if you have a propane torch, it helps to heat it up for about a minute or 3. |
#3 (permalink) |
good choice on the PB blaster, that should help loosen it up. i just did brakes today and cranked on the bleeder valves pretty good after some PB and they came loose without breaking.
__________________
The PATYWGN: 1998 4Runner Desert Dune Pearl. PATYWGN show-off thread PATYWGN on Cardomain Pattycakes77 on Myspace! let me be your friend... please? |
#4 (permalink) |
Thanks...i will do that.....if i happen to break it is this a big problem? is it easy to replace those things? will fluid come gushing out and I will not be able to use the runner?
__________________
#5 (permalink) | ||
Use a set of vice grips and get it all the way out then replace with new valve....It has been the best solution for me yet....just make sure the reservoir is full and that u have the new valve before hand.
I dunno about the torch idea...remember...brake fluid is flamable.... I only say this cuz I have seen ill effects from doing it.
__________________
Quote:
Quote:
93 Runner, 3vze, auto, 4.88 gears, 31" tires, mostly stock, 255k and counting DD: 94 runner, 3vze, geared 4.56, m/t, 31/10.5/15, only 200k on the clock Project: 91 p/u, 3vze, m/t, 2" body lift, 4.10 gears, 33's, 219k on the clock. It's becoming an addiction. Last edited by Team420 : 09-06-2008 at 06:16 PM. |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| LSPV bleeding (rusted bleeder valve) | PCE91V64x4 | 86-95 Trucks & 4Runners | 3 | 02-02-2008 12:27 PM |
| stuck egr valve on 93 Camry | DuB | General Vehicle Related Topics (Non Year Related) | 1 | 03-25-2007 09:47 PM |
| Stuck PCV Valve | deathrunner | 95.5-2004 Tacomas & 96-2002 4Runners | 13 | 12-18-2006 05:48 PM |
| Stuck CV axle and stuck front diff drain plug. Help! | Buddyman | 95.5-2004 Tacomas & 96-2002 4Runners | 18 | 08-07-2006 12:47 PM |
| How can I tell if the EGR valve is stuck open? | YotaJunky | Maintenance & Repair Archives | 16 | 10-26-2005 12:26 PM |
