Help!!! Alarm is stopping me from starting the truck - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 06-17-2007, 11:25 AM   #1 (permalink)
So I got married last night. I need to drive back to KC today so we can go on our flight out to go on our honeymoon. I have a 02 with the Commando FM-870 alarm.
The alarm is going off and I can't stop it with the remote or with the switch inside. It is preventing me from starting the car!! So, I am trying to see where to unplug it or something. Any ideas?? HELP ME!!! Thanks
__________________
2002 4x4 SR5
wsudu is offline
Old 06-17-2007, 11:29 AM   #2 (permalink)
Elton's Avatar
Send a message via AIM to Elton Send a message via MSN to Elton
think your truck is jealous better have a long talk with her
__________________
My Truck 98 4runner SR5 3.4L 5spd 4x4 E-Locker Mods
Mom 07 Tundra d-cab limited 5.7L 4x4 auto
sister 92 pickup SR5 X-cab 3.0L 5spd 4x4
Papa 89 Pickup SR5 X-cab 4x4 3.0L 5spd/98 4runner SR5 4x4 auto 3.4L
R.I.P 91 4runner SR5 4x4 3.0L 5spd Totaled 5/13/06 My Wreck
Elton is offline
Old 06-17-2007, 11:30 AM   #3 (permalink)
frodin1's Avatar
Can you disconnect & disable it?
frodin1 is offline
Old 06-17-2007, 11:33 AM   #4 (permalink)
MillerPKA's Avatar
way to help elton, its not like he has a honeymoon flight to catch or anything
i'd call the manufacturer and explain the situation. if your kill switch that was mounted in the cabin isn't working i can't think of anything that could bypass the engine connectors. above anyone the makers should know how to get your alarm disabled and your car running again
__________________
883/LC with OME/PC shocks ∙ 2" body lift ∙ ARB bull bar ∙ Safari Snorkel ∙ KC/IPF aux lighting ∙
315/75 BF Goodrich KM2s ∙ LC Wheels ∙ Vortex Cherrybomb ∙ Custom black/tan color scheme ∙ couple other things
Toytec 4Runner Catalog
MillerPKA is offline
Old 06-17-2007, 11:35 AM   #5 (permalink)
91muddog's Avatar
i had a clifford matrix in my 91 p/u
we disonnected it at the power source and it started right up.
__________________
1995 Toyota Avalon: 3.4 Auto with ect power button
Quote:
Originally Posted by stormin94 View Post
And changing your blinker fluid regularly reduces build up, and allows for higher visibility. But only use the Toyota brand from the Toyota dealership.
Quote:
Originally Posted by SwampThing View Post
Holy front shackles batman!
[/size]
91muddog is offline
Old 06-17-2007, 11:46 AM   #6 (permalink)
The alarm company is closed......We are opening gifts right now and I think after this I am just going to try and look around to see if there is a harness. The flight doesn't leave until tomorrow but I need to leave to go back home today.
__________________
2002 4x4 SR5
wsudu is offline
Old 06-17-2007, 11:56 AM   #7 (permalink)
I just did a search and i dont know if this is going to help but read page 7
http://www.commandocaralarms.com/man...-870owners.pdf
I dont know if you tried it already
bsebllhglyknit is offline
Old 06-17-2007, 12:46 PM   #8 (permalink)
reggie 00's Avatar
Send a message via AIM to reggie 00 Send a message via Yahoo to reggie 00
How are you trying to use the button inside. On mine i think i have to turn the key on and press the button. The one in my Tahoe i have to hit a coded sequence.
Ok straight form manf website:
J. DISARMING WITHOUT A TRANSMITTER ( Alarm Feature III - 1 Programming )
OVERRIDES THE ALARM WITHOUT PASSWORD PIN CODE: (Factory Default Setting)
The Override function may be used if the remote transmitter is lost or inoperative.
1. Enter the vehicle and turn the ignition switch to 'ON? position. (Alarm will sound.)
2. Within 10 seconds push and release the valet switch
The alarm will stop sounding and enter the disarm mode. You can now start and operate the vehicle
normally.
OVERRIDE THE ALARM WITH PASSWORD PIN CODE: (Alarm Feature III - 1 Programming)
Unlike valet switch easily found, and defeated, this security system allows the consumer to program a
password pin code. Offering a higher level of security.
2. Within 5 seconds, enter your chosen the first digit code by press and release the Valet Switch.
(When finished above procedures, system's siren stop alarming, parking light stop flashing, but the
vehicle can not be start and drive away.)
3. Within 15 seconds of the last digit code enter (the 1st code), turn the Ignition Switch ?OFF? and then
?ON?.
4. Within 15 seconds, enter your chosen of the second digit code by press and release the Valet Switch.
5. Turn the ignition switch ?OFF? position.
[4] Chirps form siren/horn, [3] flash from parking light to indicate the system was disarmed.
Note 1: You must override the alarm within 60 seconds. If not, the system will automatically re-arm.
EXAMPLE: To Override The System With The Password Code 83, you would;
2. Within 5 seconds, Press and Release the Valet Switch 8 times
(When finished above procedures, system's siren stops alarming, parking light stop flashing, other
sensor stop trigger, but the vehicle can not be start and drive away.)
3. Within 15 seconds of the last digit code enter (the 1st code), turn the Ignition Switch ?Off? and then ?ON?.
4. Within 15 seconds, Press and Release the Valet Switch 3 times
5. Turn the Ignition Switch to ?Off? position.
Alittle Google.
http://www.commandoalarms.com/itm30032.htm
Oh ya congratulations
__________________
'83 Truck 4x4 - 4" lift, downey header,, lots of stickers.
'90 Runner $600 project ,32's on black Steelies,Optima Red Top, 1.5" Balljoint Spacers, 80 series Coils, Sleeping/Storage Platform extravaganza
You know enough to be dangerous, get out the way before you break something i can't fix- Pops
Bah, you are such a moose...
Rota est Fun!
Quote:
Originally Posted by ChickenLover View Post
Just get a bowl full of it, and dip 'em in.
http://www.4x4support.com
reggie 00 is offline
Old 06-17-2007, 02:07 PM   #9 (permalink)
i tried that but the alarm is not at all responding to the inside switch. I know there is no pin code because i am too lazy. I just want to unplug this stupid thing. Oh well
__________________
2002 4x4 SR5
wsudu is offline
Old 06-17-2007, 02:30 PM   #10 (permalink)
INFINITY's Avatar
if it does not let u start it when it is going off then it is wired so it bypasses the starter/ignition line from the ignition to the starter. try getting a new batt for the remote, other than that good luck
INFINITY is offline
Old 06-18-2007, 04:04 PM   #11 (permalink)
icerunner's Avatar
Disconnect the alarm at its power source , hopefully that will do the trick.
icerunner is offline
Old 06-21-2007, 02:41 PM   #12 (permalink)
cvlighthouse's Avatar
Send a message via Yahoo to cvlighthouse
Not sure if you tried this and it's to late, but disconnect the battery and then turn your key to the "on" position and then re connect the battery.
__________________
01 Taco TRD w/ cab over camper here: http://www.yotatech.com/showthread.php?t=116933
Replica Ivan Stevart TRD grille here: http://www.yotatech.com/f2/01-tacoma...-alike-136935/
cvlighthouse is offline
Old 06-21-2007, 02:47 PM   #13 (permalink)
Quote:
UNPLUG IT. then start your car... thats all i did. reach under there and pull the plug from the alarm. or just take out the fuse which runs from one of the wires coming from the alarm box.
__________________
1990 toyota 3.0 v6 xtra cab sr5, 5 speed manual
hannemann tacoma front end conversion,
downey headers, turned down 2 1/2" exhaust
Centerforce dual friction clutch
3" body lift
4" suspension lift IFS
4.88 front and rear, lincoln locked
15x10 black rock crawlers w/35x12.50x15 BFG Mud T
Azusacanyonbogger is offline
Old 07-02-2007, 02:26 PM   #14 (permalink)
4x4banger's Avatar
If re-setting the power (unplugging ,disconnecting the battery,fuse,etc,)doesn't work,you gonna have to remove the whole alarm system.Look under the dash,steering column area and you should see the unit and wiring.Disconnect battery(ground terminal)and start disconnecting the wires,careful you might have to splice back the original "cut"wires.You should also see a relay wired to the ignition switch(follow the ignition wires)solder your connections!Remove all aftermarket wiring,including wires to the brake switch if equipped with remote starter.Take your time.
4x4banger is offline
Old 07-02-2007, 03:40 PM   #15 (permalink)
Thanks, I finally got it later that day. I think it just tripped out. It seems good now. I did the battery trick and I think it seemed to work. Thanks
__________________
2002 4x4 SR5
wsudu is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
What to do before starting after a truck has been on it's roof? TomThumb General Vehicle Related Topics (Non Year Related) 16 01-25-2007 12:13 PM
Need help with an alarm that came with truck Lance Alarm Systems 6 05-22-2006 11:51 AM
Need help with truck starting jerbear Maintenance & Repair Archives 3 06-13-2005 07:39 AM
Hard starting, alarm back on, lights blinking randomly, HELP?! Randomness 95.5-2004 Tacomas & 96-2002 4Runners 11 05-17-2005 11:15 PM
mY TRUCK ALARM HAS GONE CRAZY! please help 904wdPickup 95.5-2004 Tacomas & 96-2002 4Runners 5 07-24-2004 09:02 PM
2009 InternetBrands, Inc.
