Help with Activating the RR DIFF LOCK with the ARB switch
For those of you who have done this mod I need some verfications.
Im following larsdennert instructions.
Looking at the brown connector I see the numbered pins 11115 on the first cluster of connectors.
Im assuming pin 5 is farthest right correct?
I loop a wire connector back to itself in pin 5. If I do that won't the looped wire impede with the connecting of the brown connector to the instrument panel?
If it is possible can you make a quick drawing from the photo as a visual?
Re: Help with Activating the RR DIFF LOCK with the ARB switch
FS[GreatLakes]: Wanted: 4.88 front diff, rear 8'' 4.88
jaretstuff
08-04-2015 02:08 PM
Athansinis
07-27-2015 08:38 AM
Steven.m.paulk
07-24-2015 01:44 PM
