Help !!!!!
Old Dec 8, 2004 | 06:21 AM
CORNEJO's Avatar
Question Help !!!!!
HELLO !!!
I HAVE BEEN KRAWLING FOR ABOUT 2 YEARS NOW ..... I LIVE IN MEXICO AND TOYOTAS ARE NOT VERY COMMON AROUND HERE.....
I JUST BOUGHT A 4RUNNER 1994 SR5 AND WANNA MODIFY IT SO I CAN KRAWL ON IT. AS I SAID BEFORE TOYOTAS ARE NOT COMMON IN MEXICO AND THAT IS WHY I AM ASKING FOR HELP.
AS WAS THINKING ON A SUSPENSION KIT OF 4" SAKYJACKER, BUT I WOULD RAHTER WANT A 6", WHICH BRAND CAN GIVE 6" ????
DIFERENTIALS ????
DO ARB AIR BLOCKER WORK NICE ON THE TOYOTAS ???
SNORKEL ??? WHICH BRAND
TIRES SUPER SWAMPER TSL 33x12.5 R16 ??? WHICH YOU RECOMEND ??
BUMPER AND WINCH ??? WHICH BRAND AND MODEL.
IF YOU CAN HELP ME OUT HERE I WILL BE UPLOADING PICS OF ALL THE MODIFICATION ON DE 4RUNNER.
THANKS FOR YOUR HELP !!!
CORNEJO
ZA ZA ZA YACUZA
Old Dec 8, 2004 | 06:37 AM
rimpainter.com's Avatar
First off, turn the CAPS LOCK off on your keyboard.
My first question is: Have you read and searched about this here on Yotatech? There is so much info about this, you will be amazed.
A better approach on your part, would be to present your questions in a fashion that shows you have done some research. For example:
“Hey guys, I am turning my rig into a rock crawler. I have done some searching here on Yotatech and the web, and have narrowed my suspension lift kit prospects down to two possibilities: Kit A, and Kit B. What do you guys think about those kits? Since I want to rock crawl and run size X tires, should I re-gear from my current ratio which is ___? I am thinking about going with front and rear ARB lockers. Does that sound good?”
Trust me, start there and you will get more info than you ever wanted from the experts.
Good luck on your quest!
