Help...2000 Auto Climate Control Troubles
The auto climate controls in my 2000 Limited have pretty much stoped working all together. I can adjust the temp and fan speed with the knobs, but do not have control of where the air blows, can't turn on the A/C, can't get it into AUTO mode, and can't switch from fresh to recerculate (all buttons don't function.)
The problems started maybe 3 months ago, but I could always get what I wanted, some times it would just take a few tries pressing the button over and over again. Now I don't have any control except for temp and fan speed. It seems to me that maybe the switch contacts are just dirty...does anyone know wether the front plate can be pulled off the the contacts cleaned? Can the entire unit be "RESET" ??
I called toyota, they had no ideas for me, except a new auto climate control unit at $700 plus install. It has been 35 deg C (95 F) for the past week...I need my A/C!!
I was having the same problem but not as bad, so this thread inspired me to get back in the climate control area. I yanked 'er and fiddled around and spayed some electrical contact cleaner behind the switches..put it all back together,,,waited a few minutes for good measure and sure enough it works sweeeeettt.
Took it all apart and cleaning the little black switches behind the buttons with electrical cleaner. Still not working. Any other ideas?
Bump....Anyone have any ideas where I could get a replacement set of auto climate controls? Could I put in a set of manual ones? I need to fix these things!
Had the same problem with my '00 Limited after storing it for a few weeks. After screwing up a couple of times it seems to be working ok now. Had a look at the factory manual and there are a whole mess of sensors that have input into the control. I would check the sensors first before investing in a climate control unit.
mine does the similar problem.
except when i try to switch the A/C on the outside temp. button is pushed instead.
i just hold the outside temp button and then press the A/C and it works.
where do you buy electrical contact cleaner?
I purchased my contact cleaner at "Canadian Tire" but I have seen it at lots of auto parts stores like NAPA, AUTOZONE, etc.
Found a solution yet??? I have a 99 limited and the on/off switch is doing the same thing on the climate control. I have to push it pretty hard to get it to turn off. I had a corvette and the climate control started doing some wierd stuff. Turned out that a bunch of others had the same problem with there vettes and I found a really good write up on the console / dash removal and then very detailed instructions on how to take the climate control apart and clean. It worked great after that....
Anybody have a similar write up on the 4runners?
provided that there are no problems with the button(s) and microswitch(es) behind them...
run the diagnostic routine and see what codes come out
[if this is the automagic climate control, when you turn the key you get
diagnostic codes]
To access the diagnostic codes, hold down the auto and recirc/fresh air buttons at the same time while turning the ignition to on.
You'll see that all indicator lights and LCD elements should flash four times followed by any problem codes.
I get code 14 when it is dark out. 14 is solar sensor. when sun is out, no codes.
diagnostic codes]
i have the same prob as the op, it all started a few days ago....all buttons are crayze, either don't work at all or get stuck, sometimes i can ge them to work if i push a bunch of times or hold them for a long time but mostly not at all. frustrating and with my temper i already pushed the whole panel into the dash! heard something snap...hope i can fix it.
too bad about all the supposed sensors....i was hoping to just replace it with a used one and be done with it. found a used one for $249!!!!
ugh....winter is coming....nice. no defrost.
i heard it is NOT interchangable with the manual one out of an sr5??
Auto climate control problems continue
Since my initial post I have replaced my unit with another used unit from Ebay. It cost me $170, but all the buttons do function. I gave my old unit to my buddie who is a electronic tech so hopefully he will take it apart and diagnosis a problem. When I find out I will let you all know.
The Units out of the SR5 are not interchangeable, SR5 has a manual box, limiteds are digial with servo's. I have heard that the units out of the 2002-2003 Tacoma's will work, the harnesses just have to be switched. Anyone have any more information on this?
I have a seperate problem now. The temp sensor in the truck does not seem to be functioning. I can have the controls set at 65 deg, and it blows full hot all the time, even when it is 100 deg in the truck. Only way to get cool air is to set it below 65, and the display changes to "COLD" then I get cool air from outside. There must be a sensor someplace that controls this, any idea where it is and how to fix it?
the black bump thing on the dash is a solar sensor not a heat sensor
it detects light. that is all it does.
run diagnostics in the dark, code 14
shine a flashlight on that sensor, run diags, no codes.
diagnostic codes]
diagnostic codes]
i know that was a smart ass thing to do, but i couldn't resist! hope you get your problem solved, i'm so glad i have the manual controls although those can break too, the controls on my dad's car broke a few years ago and we have to disassemble the dash every fall and spring to switch it from cold and hot depending on the season!
