Help!!!!!!!!
Help!!!!!!!!
To start off... I have a 1998 4runner limited. I started my brake upgrade to tundra calibers and rotors. I started my brakes earlier today and the driver side was easy...
Then I started on the passenger side and it was a pain is the F*#^ a**. Well finally got the caliber off and the top screw is..........ya my luck....IT IS STRIPPED!!!!! The treads inside the part that the caliber bolts to looks like it may be damaged also!
I need help! What if anything can I do..????
Its a threaded insert you use, you would probably have to chnage the bolt size but they work well..
http://www.emhart.com/products/helicoil.asp
