| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
__________________
2004 SR5 4Runner 4x4, Husky Liners, Scion HU. Future Mods: OME lift, 265-70-17 Nitto Terra Grapplers |
#2 (permalink) |
Bad light switch in your dash maybe? I'm sure others will have some ideas later, but that's all I can think of now at the moment.
__________________
'99 Taco PreRunner V6 3.4L
#3 (permalink) |
I used the ignition fuse, in the cab, and the lights work.
mochoajr
__________________
#4 (permalink) |
Ground
Check to be sure that the lamps and the switch are grounded properly. Everything else could be in order exept the ground.
__________________
96' 4Runner Limited 4x4 01' Corolla S Former "Toys" 92' Pickup 4x4 Xtra cab V6 98' Corolla LE 81' Celica GT |
#5 (permalink) |
Help on Hellas Part II
I wired the hot wire from the switch to the in-cab ignition fuse. The engine would crank over, but not run. When I took the hot wire out and just put the fuse back in, the engine would work.
Anyone have any ideas? Or, how should I connect the hot wire from the switch? Thanks, mochoajr.
__________________
#6 (permalink) |
wire
You should have a hot leg from the battery to the relay(red)with a inline fuse. A ground from the battery to the relay(black).Green from the relay to the switch(hot leg). blue from the lamps to the relay. Green from the switch to either headlamp lowbeam for fogs, highbeam for driving lights or parking light for the ability to turn them on with high, low or parking lights.Thats it
__________________
#7 (permalink) |
In case
I'm guessing that you dont have a wiring diagram. But the red to relay go'in the 30 spot, black to 85, blue to 87 and green to 86. Also the switch, top is ground middle is green from relay and bottom goes from the light source high, low, ect. Hope this helps
__________________
#8 (permalink) |
Co-Founder/Administrator
Staff
Marco, got your emails also.
I would not use the ignition fuse in the cab to run to your switch. Did you read my write-up in the Tech section on wiring up off road lamps? Before I installed my extra fuse box under the hood, I used the cigg lighter fuse I think for the switches power source. Try using a fuse that is either hot with the key off if you want full control over the lamps, or use a fuse there that is only hot with the key on. The reason I don't tap into any of the in cab fuses anymore is explained in my write-up. I also have the Hella wiring diagram scanned in and linked in the write-up.
__________________
Corey 2007 FJ Cruiser Built for 4wheelin', expedition, camping, and overlanding use PNW FJ Cruisers ☺ Detailing 101 ☺ Join Topsites ☺ Muffler Comparisons ☺ Maggiolinas In The Wild FJ Cruiser Buildup ☺ New Roof Top Tent ☺ Video Of My Penthouse Part II ☺ Rehinge Your ARB/Engel Fridge Blog About Roof Top Tents ☺ FJC Magazines Online Review Of My Tent ☺ 2009 Specialized Rockhopper Pro |
#9 (permalink) |
Thanks to everyone who responded.
Thanks Corey, I'll print your tech article and read it. Thank you very much for your help. Marco.
__________________
#10 (permalink) | |
Quote:
I read your write-up numerous times and I am about to install some hellas this weekend(500's). I want to be able to turn them on when ever the key is on, or preferably anytime that I want; not only when the high beams are on like the hella instructions say. How do you tap into a fuse, like the cigg lighter one that you previously used before your extra fuse box install? Is is a bad idea to run a wire from your battery(with a inline fuse), to the switch, and from the switch to the lights; all with the proper grounds? Or is is best to incorporate a relay like the directions instruct? Thanks, Chris |
#11 (permalink) |
Staff
You should use a relay, that is what they are for.
Very easy to hook up after you study it for awhile. To tap a fuse, all you do is pull the fuse out, and then stick your wire in there and muscle the fuse back in again. It might take a few tries. The ultimate setup though is to go with an external fusebox like I did, and not worry about tapping any fuses. I have all three sets of lights on one fuse in the new fusebox. The wires only need a small amount of current to engergize the relay with, and that is those wires jobs. |
#12 (permalink) | |
Super Moderator-Sponsoring Member
Staff
Hellas
Quote:
Hella 500 Fog Light Write-Up
__________________
WabFab Off-Road, LLC MySpace 7th Annual South East 4Runner Jamboree, 2010 The toughest part of a Jeep is the chick driving it. WabFab Off-Road 4th Anniversary Sale Last edited by waskillywabbit; 01-09-2004 at 11:16 AM. |
#13 (permalink) |
Hellas
Brian,
How did you get the wires through the grommet? It's pretty tight there. mochoajr
__________________
#14 (permalink) |
Hellas
Chris,
There is an adapter you can buy at Autozone or Pepboys. I don't know the name, but it looks like a slightly larger fuse with a wire coming out of the side. On top of the adapter there are two slots to insert two 5 or 10 amp fuses. The wire that comes out of the adapter, you splice to the green wire coming from the Hella light switch. Just follow the instructions to the adapter. I used the ignition fuse that's in the in cab fuse box. As long as I have the key on, I can turn on the Hellas. mochoajr
__________________
#15 (permalink) | |
Staff
Re: Hellas
Quote:
__________________
WabFab Off-Road, LLC MySpace 7th Annual South East 4Runner Jamboree, 2010 The toughest part of a Jeep is the chick driving it. WabFab Off-Road 4th Anniversary Sale |
#16 (permalink) |
Hellas
....and some 'protection'??
__________________
#17 (permalink) |
Thanks Corey, Brian, and mochoajr
I appreciate the responces. I guess that I have some work cut out for me tomorrow. I'm planning on picking up one of those OEM fog light switches in the morning. I'll see about one of those fuse adapters as well. Brian I read your write up also. Very good write up, very detailed and the pictures help a lot as well. I appreciate the help. I'll keep ya'll posted on the outcome. Thanks, Chris |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Hella 500's not working. | 4runnersurf | General Electrical & Lighting Related Topics | 6 | 10-20-2007 05:36 PM |
| hella 500's...any wattage? | 89red4x4yota | General Electrical & Lighting Related Topics | 7 | 02-11-2007 09:28 PM |
| Hella 500's | 95RunnerSR5 | 86-95 Trucks & 4Runners | 20 | 08-05-2006 03:20 PM |
| Hella 500's are on | 4x4Fink | 95.5-2004 Tacomas & 96-2002 4Runners | 24 | 03-29-2004 07:27 PM |
| Hella 500's | CMD93 | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 01-18-2004 05:00 PM |
