Hella 500's - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 01-18-2004, 03:44 PM   #1 (permalink)
CMD93's Avatar
Hella 500's
Hey guys, thanks to WasklyWabbit and Corey's help with their write-ups, I sucessfully installed my Hella 500's this weekend. A pretty easy install. I got the OEM fog light switch from the dealership and just followed the writeups from Brian and Corey.
I think that they look great on my 2nd generation.
Thanks for the great write ups,
Chris
P.S.
1.) Did you guys use any paint on the bumper where you drilled through to inhibit rust. I used some rubber grommets up against the chrome for protection.
2.) Is it ok to have several things ground on the same place?
Example: Can both the lights ground on the same bolt or do they need to be seperate?
Thanks again
CMD93 is offline
Old 01-18-2004, 03:57 PM   #2 (permalink)
Super Moderator-Sponsoring Member
Staff
waskillywabbit's Avatar
Send a message via AIM to waskillywabbit Send a message via MSN to waskillywabbit Send a message via Yahoo to waskillywabbit
Re: Hella 500's
Chris
I do the write-ups to help folks who need some help just like I did. Sometimes I found some good info a bunch of different places and sometimes there was very little info. I'm glad I could be of some help, as bamachem helped me with the install.
Quote:
P.S.
Thanks again
1. I didn't use anything but I am going to get an ARB/TJM on down the road and then put some grommets in there to cover up the holes, so I didn't really worry about it.
2. I ground everything off the same ground that the battery uses and ran both light ground wires together and then to the ground. Works fine that way and easier to de-bug if something goes wrong.
This thread needs some
waskillywabbit is offline
Old 01-18-2004, 03:59 PM   #3 (permalink)
Sponsoring Member
midiwall's Avatar
Re: Hella 500's
The grommets are a good idea, but you still have unsealed metal laying around. You should paint the inside of the hole with a rust inhibitor, then put the grommets back in.
Quote:
2.) Is it ok to have several things ground on the same place? Example: Can both the lights ground on the same bolt or do they need to be seperate?
When talking about something like lighting, yes, you're okay grounding both lights to the same bolt. Separate grounds are a good idea when you're comparing something like a CB antenna and lights or a power inverter.
The difference between the three being an RF signal, constant DC drain, and spikey DC current.
Congrats on the install!
__________________
~ Mark
'96 4Runner Limited S/C MI - 370cc injectors, Air! horns, Airaid MIT, ATS A-arms, 285/75/R16 BFG MTs, Bored TB, Brembo slotted, Cobra 75 WXST, Deckplate, Downey headers, Hayden cooler, IPT valve body, Level 10 torque convertor, Meanstreak exhaust, OME/OME rears, On-board PC (XM, Nav, WiFi, etc), Port 'n Polish, Remote Start, SAW fronts, Hilux console, SMT-5, Stubb's sliders, Supra MAF, TJM-17, 2.0" pulley, Viair 450c, Walbro 190, Weasy2k cams
midiwall is offline
Old 01-18-2004, 05:00 PM   #4 (permalink)
CMD93's Avatar
Yea some pics would be nice. Maybe I can borrow one from work and post some pics.
I guess that I will paint the unsealed chrome to protect it.
Thanks for the tips.
The next install will be differential breathers front/rear and amsoil in the tranny and differentials.
CMD93 is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Hella 500's not working. 4runnersurf General Electrical & Lighting Related Topics 6 10-20-2007 05:36 PM
hella 500's...any wattage? 89red4x4yota General Electrical & Lighting Related Topics 7 02-11-2007 09:28 PM
Hella 500's 95RunnerSR5 86-95 Trucks & 4Runners 20 08-05-2006 03:20 PM
Hella 500's are on 4x4Fink 95.5-2004 Tacomas & 96-2002 4Runners 24 03-29-2004 07:27 PM
Hella 500's Help! mochoajr 95.5-2004 Tacomas & 96-2002 4Runners 16 01-09-2004 05:04 PM
2009 InternetBrands, Inc.
