Hella 500 install
Old 08-04-2005, 04:15 PM
Lone4runner's Avatar
Hella 500 install
Help ! please i ve read many articles and assume im stupid. here goes i understand everything in the install except i want the switch to turn on whenever not determined by high/low beams just by a live wire. so on the swith there are 3 plugs one to the relay. one for the ground and one to normally be tapped into the high/low/ parking lights. someone here suggested a fuse block which i dont have nor know how to hook up. so whqat are my options for that one wire??? can you put an inline fuse straight to the battery or do i need a fuse block? if so how to hook up ??
Old 08-04-2005, 04:40 PM
TDiddy's Avatar
In line to the battery will work just fine, that's how I had mine hooked up.
Old 08-04-2005, 04:45 PM
Co-Founder/Administrator
Staff
Corey's Avatar
Did you see my article in the tech section?
Old 08-04-2005, 04:54 PM
[QUOTE=Corey]Did you see my article in the tech section?
I did but i just didnt understand it cause it looks like you and bob ran it through a auxillary fuse block which i dont know how to use or have one. i do plan on getting one but at this time it complicates thing i guesss how does a block wire up?
TDiddy but if i just run that lead wire directly to the battery im ok with an inline fuse?
Old 08-04-2005, 04:58 PM
Staff
Corey's Avatar
I did have them installed before the aux box.
You can see in my aux box article how I had tapped the Hella wire into the incab fusebox.
Old 08-04-2005, 05:00 PM
TDiddy's Avatar
Yep that's correct...
Old 08-04-2005, 05:01 PM
so are you saying for the green (hot wire) can have an inline fuse and go straight to the battery?
Old 08-04-2005, 05:02 PM
nice : )
Old 08-04-2005, 05:06 PM
i maybe pushing it but in this case why would i need the relay then? couldnt i just have the grnd wire, and a hot wire and thats it?i noticed some cheaper lights like fogs dont require a relay?
Old 08-04-2005, 05:08 PM
Staff
Corey's Avatar
No relay = fire.
Relays are the safest way to go.
Old 08-04-2005, 05:10 PM
TDiddy's Avatar
Agree - fuse + relay is OK, but be sure to use them both.
Old 08-04-2005, 05:13 PM
Bob_98SR5's Avatar
do you want your hellas to always turn on with your lights? i sure dont!
bob
Old 08-04-2005, 05:55 PM
bob
nope not at all i just wanna control them when ever i want. so what is the best way then ? in your opinion? right now im doing everything like the instructions say excep the green wire off of the switch is gonna have an line fuse with it taht goes to the positive terminal. even though the relay has a fuse already
Old 08-04-2005, 06:24 PM
Gangus2006's Avatar
What I did was tap one of the fuses int he cab with a Mini Add-A-Circuit, sent that to a switch, and the switch went to the relay. So even if I leave my switch on, if the Ignition is off, the lights wont be on, therefore wont drain my battery.
Old 08-04-2005, 06:29 PM
i dont mind having the ability to turn the lights on w/o the ignition on im kinda weird anyway i look at my truck like 3 times after i walk away from it lol
i was just worried that the lights are being hooked up to the battery twice. once from the positive terminal of the battery to the relay then from the switch to the postive battery again is all. i know it doesnt take much to understand but i think im more mechanical than electrical : )
Old 08-04-2005, 07:43 PM
jimbo74's Avatar
do a sear for my name and aux light wiring... tons of info... i originally had my lights just on a seperate switch and later added on automatic to the highbeams... i can still turn them on all by theirselves too
Regency
20
01-03-2020 07:43 PM
RyanV
05-14-2016 08:24 AM
shisha1999
09-21-2015 08:22 PM
Alex Bessinger
08-31-2015 09:17 AM
lectric80
08-11-2015 12:02 AM
Quick Reply: Hella 500 install
