Heli-coil kit for 3.4L oil pan to block bolts
Old 05-21-2014, 07:02 PM
mussy01's Avatar
Hi all,
Just curious if anyone has used heli-coils to repair stripped bolt holes on aluminum block for the 3.4L engine at the oil pan? I've got a couple that appear to be a bit stripped that I would like to fix for good.
I'm having difficulty identifying the exact size and thread of the OEM bolt, but here is the toyota part #90119-06727. I will attempt to track that info down from the local dealer tomorrow.
Does anyone have a specific kit they used with success in the past? Any tips on installation that you found useful?
Thanks!
Old 05-21-2014, 07:44 PM
scuba's Avatar
Sometimes the RTV will get in the holes and make things tight. I'd try a hefty dose of brake clean and a good tap before a heli-coil.
Old 05-21-2014, 07:48 PM
Yotard's Avatar
As a machinist I highly recommend keensert over helicoil. Order from McMaster Carr in whatever size you need. Way stronger and rather than using helicoil tap uses standard tap.
Old 05-21-2014, 11:00 PM
wyoming9's Avatar
Red face
The threads will be either a M6x1.00 Or M8x1.25 working on Toyota vehicles I also have the M10x1.25 and the M12x1.25 thread replacements
I really think Helicoil has become the common word for any type of thread replacements
bigjstang
08-25-2021 12:41 AM
09-04-2015 09:27 AM
jon.r
07-11-2015 03:34 PM
87blyota
07-10-2015 04:31 AM
Gamble_STi
07-07-2015 07:54 PM
Quick Reply: Heli-coil kit for 3.4L oil pan to block bolts
