heating and cooling issues
Old 12-05-2005, 03:52 PM
mike_04's Avatar
Ok I did a search and can’t find anything on this issue, my girlfriend has complained quite a bit so I thought I would post this before I start taking stuff apart when it‘s minus 15 outside. In the winter the driver side vents are a lot hotter than the passenger side, no matter what setting it is on. And in the summer time it’s the other way around. The driver side is cooler than the passenger side with the ac on. Any ideas.
Old 12-05-2005, 03:54 PM
marko3xl3's Avatar
It's probably a fault in the centing system. I am assuming that one of the flaps that directs air lets more air through to the driver's side than the passanger side, but I am not certain. Worth takin' a look at though.
Old 12-06-2005, 05:08 AM
Babypig's Avatar
I have the same problem. The passenger side actually has a lot of cold air blowing in when driving. I closed up the hole where the shifter goes through the floor and the problem has pretty much dissappeared. I just used a peice of rubber neoprene and made a nice tight hole for the shifter to go through. Sealed it up with acoustiseal and it helped a lot. Also check that the rubber hole fillers on the fire wall are all still in place.
bigjstang
08-25-2021 12:41 AM
Sleaker
08-26-2020 06:03 AM
the1998sr5
15
07-14-2020 08:35 PM
the1998sr5
27
11-17-2015 09:30 AM
Coreyr384
07-10-2015 11:13 AM
Quick Reply: heating and cooling issues
