heater core or valve problems? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 12-02-2006, 07:12 PM   #1 (permalink)
nieveparasiempre's Avatar
'98 V6 tacoma:
i changed my clutch on my tacoma recently. to get to the top bolts i unbolted and moved the heater valve off the firewall. since then, the cable to move the valve to hot/cold is stuck @ 2/3's what it's supposed to and the heater only has a 1/3 the heat it normally does. i've taken off the cable and turned the valve to both extremes, both of which blow even colder air. with the cable on, i get the "warmest" 1/3 air. the vents still blow at full capacity.
so bad valve? or bad heater core?
nieveparasiempre is offline
Old 12-02-2006, 07:45 PM   #2 (permalink)
Greedy's Avatar
I recently had this problem too. Turned out to be the cable that goes from the bottom of the cold/hot knob to the right, behind the glove box, under the golve box and back behind the center console at the bottome near the firewall. There is a door there that allows the hot air into the vent tubes (you can reach back there and manually flip the door open and closed to verify if this is the problem). My cable was bound up at the knob and eventually came off as I was forcing it to turn. Had to take the center dash parts off, unscrew the control box and re-attach the cable but now it works perfect!
__________________
- 1999 4Runner Highlander Edition
- Turbonetics BB T3/TO4E TURBO
- URD Fueling
- 3 Inch Turboback Exhaust
- 16x8 Volk TE37X
- OME Lift
Greedy is offline
Old 12-02-2006, 08:27 PM   #3 (permalink)
SC4Runner's Avatar
All I know is a bad heater core usually just equates to coolant leaking. So, its probably something else.
__________________
1996 4x4 3.4L 4Runner on 35's - 6" of lift, MTR's, E-locked, ARB Tacoma Bumper, Sliders and a cut off tail pipe.
1966 FJ40 - SOA with stock springs, stock 1F motor, and a smelly tailpipe.
SC4Runner is online now
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
heater core? 86toysr5 95.5-2004 Tacomas & 96-2002 4Runners 1 04-13-2007 06:37 PM
heater core replacement? vwfastg60 84-85 Trucks & 4Runners 7 12-03-2006 05:39 PM
Removing heater core FSRBIKER 95.5-2004 Tacomas & 96-2002 4Runners 6 01-02-2005 08:44 PM
Cleaning a heater core FSRBIKER 95.5-2004 Tacomas & 96-2002 4Runners 7 12-03-2004 09:19 PM
possible heater core trouble kford 95.5-2004 Tacomas & 96-2002 4Runners 0 04-13-2004 08:09 PM
2009 InternetBrands, Inc.
