Heads up to anyone with Lightforce Lights...
I recently got a pair of 170's, and mounted them all up, my friend also has a pair... but they were different... in my package it had on top a bag that has a label that said you must install this or it will void the warranty... what was it? It was a breather kit... you ran tubing that went from the back of the lights to a higher point and the end was a filter... so I was confused... did they nix that feature? was my friends newer or mine?
So I emailed.. this is what I got...
Adam,
Your lights with the breather kit is the most recent development in our driving lights, if your friends lights have a sealed hole in the back of the light housing it can be retrofitted with a breather kit with little effort. To check if his lights have a sealed hole take a thin wire and insert into the hole to see if it can pass all the way into the housing or stops about 3/8 of an inch into the housing. We can supply your friend with a breather kit if he would like one for shipping cost only.
Thank you
Brian Gearhart
Light Force USA, Inc.
208-476-9814
Just a Heads up for you guys...
Adam,
Thank you
Brian Gearhart
208-476-9814
It seems that the breather kit is to allow pressure to be equalized in the event that the lights become submerged in water, so if you have a pair of the non-breather type lights up on the roof or above the line of a deep water crossing, they will probably be fine. If you have them mounted on a bumper, the kit is probably a good idea.
Here is a write up on retro fitting the kit on a pair of 240's
kgcwb44
01-29-2023 10:02 AM
themightykhoner
08-11-2015 07:37 PM
