Headlight wiring harness upgrade, need help! - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 06-05-2004, 04:46 PM   #1 (permalink)
904wdPickup's Avatar
Send a message via AIM to 904wdPickup
I want to upgrade my stock hadlight wiring harness on my 90 v6 pickup but don't know ich to buy. I have done some searching and found several, autobulbdepot(seems to be out of bussness), suvlight, and some universal apc ones on ebay. It seems that everyone on here uses the suvlight one, but I am not sure wich model to order.
Also it looked like on the sulivght harness you only use one of the stock female end plugs(if I am even looking at the right one for my truck)?
And if it makes any differance I have Hella Vision Plus Halogen Headlights
__________________
1990 Toyota Pickup 4x4 V6 xtra-cab
K&N FIPK, Jardine exhaust, 4" Superlift, 33x12.5 R15 Goodyear MTR's, rollbar W/ KC's,...
904wdPickup is offline
Old 06-05-2004, 06:48 PM   #2 (permalink)
anyone?
__________________
Old 06-05-2004, 07:40 PM   #3 (permalink)
SkyRat's Avatar
I have heard good things about Painless wiring, but sadly, I know nothing of your application.
__________________
George ><>
2000 4Runner Limited 4WD
TJM T-15, Warn XD9000 Winch, BFG AT/KO 265/75-16, DeMello Sliders, Yakima LoadWarrior, OME Front 882/N91S - Rear 891/N86, Fiamm Freeway Blaster Horns, Alpine CDA-9827, Cobra 75WXST w/ Firestik II, HuskyLiners, PIAA 520 Fogs, Powerslot Rotors, Optima Red Top, Cargo Storage, Inverter
But God demonstrates his own love for us in this: While we were still sinners, Christ died for us. Romans 5:8
Flickr Site
Discovery Church
SkyRat is offline
Old 06-06-2004, 02:14 AM   #4 (permalink)
mikedog's Avatar
Actually, it might be better to do what I did. When I decided to upgrade my headlight harness, I just made my own with 10-gauge wire, two relays and a fused power source. It's really not that hard to make your own DIY harness. I also incorporated the fused high/low beam circuits into the stock fuse box. I just used two vacant fuse slots under the cover to put the wires/fuses in for a clean look. I currently have the Hella H4's with the stock supplied bulbs for now.
With the huge 10-gauge wires, the 65w/55w stock Hella H4 bulbs are pretty darn bright the way it is. It's a BIG difference compared to the old X-tra visions/stock harness I had in there before.
Toyota uses a switched ground system for their headlight circuits. At least in the pre-Taco years. What you're basically doing is using the stock factory harness on your truck as the "trigger" leads to the relays while the relays handle the power from the battery to the headlight bulbs.
By using the factory harness as the "trigger" leads, you don't have to butcher anything. You can make it so you can switch back and forth from either harness in a couple of seconds. Also, if you ever sell the truck you can easily take the DIY harness with you.
mikedog is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Homemade headlight wiring harness gregbreakseverything The Classifieds GraveYard 8 10-04-2006 07:50 AM
4crawler HL wiring harness upgrade. 2wheelBLACKOUT General Electrical & Lighting Related Topics 14 02-16-2006 07:49 PM
Headlight Wiring harness/diagram Question teamblend 95.5-2004 Tacomas & 96-2002 4Runners 2 12-13-2005 10:19 AM
Upgrade headlight wireing harness Erich_870 95.5-2004 Tacomas & 96-2002 4Runners 4 05-20-2003 10:42 PM
2009 InternetBrands, Inc.
