Headlight question
Headlight question
My left front headlight is out. Changed the bulb, checked the fuse...still no dice. Right side works fine. Anything I need to check out?
You using the Factory Service Manual for your year Truck? http://www.ncttora.com/fsm/index.html
Make sure you are checking the right fuse. If that isn't right use the FSM to troubleshoot the wiring. You may have an exposed or broken wire or ground....
Electrical gremlins are truly the worst! Good Luck!
rushw
07-18-2015 01:46 PM
icentropy
07-14-2015 10:23 AM
