Headlight Options
Headlight Options
does any one know if you can retrofit 4th gen runner headights into a 3rd gen runner and if so how much work would it involve the reason i am curious i want to have the projector style headlights
if this is not possible does anyone know of a place to get the projector style lights for a 3rd gen runner
i run 80w/100w bulbs with a custom wiring harness up-grade they are bright. I ran 3 relays (30 amp , High, Low, and Fog). I noticed a big up-grade with just the wiring ans the stock bulbs, once I put in the 80/100 i feel bad using any thing but low beams. I also added 100w fog bulbs and wired them up to stay on with the high beams. I only use this combo in the desert at night, the high beams light up down range nicely but leave some thing to be desired close up this is the void the fogs fill.
i was talking bout the round style ligts and they do make them fo the aftermarket headlights for a 4th gen and thanx Ian i might try that to see if there is an improvement
And I don’t think that the 4th gen lights will fit in that well at all. You would be much better off doing a custom retrofit for the lights. Then get the HID in them to finish them off.
