Headlight conversion
Old Jul 5, 2006 | 08:04 PM
wyldrs's Avatar
Ordering some 99-02 style diamond cut headlights for my 96 limited, is there anything else i should know before i do this, or is it a straight swap, should i also change the marker lights , or are they the same .
Thanks Guys !
Old Jul 5, 2006 | 11:46 PM
JC_ez's Avatar
It's a staight swap. You can use the frosted side markers that come with your 4Runner without problem. The newer clear ones may match up better in terms of looks, but you will have no problems with installation using the old ones. I have the newer headlights with the older style side markers and I think it looks very good.
Old Jul 6, 2006 | 06:35 AM
Bennito's Avatar
Bolt on. The only rub I found was not noticing that a "ball" actually unscrewed. Took me longer than it should have (not saying how long) to realize what needed to be done.
Seriously though, it takes longer to remove your grill than to swap the headlights.
Old Jul 8, 2006 | 05:00 PM
Elton's Avatar
i really like the 99+ headlights and tail lights
live4soccer7
May 11, 2016 06:52 PM
4banginRunner
Nov 13, 2015 05:23 AM
mreagen
Oct 5, 2015 04:27 PM
beltcutter
Sep 30, 2015 06:14 AM
JPV
Sep 28, 2015 03:15 PM
