Headlight Always ON - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 09-28-2005, 01:30 PM   #1 (permalink)
maguirre's Avatar
Headlight Always ON
Hi all,
We all know that our cars have the feature where the headlights are ON during the day even when you don't turn them ON.
Is there a way to turn them off??? I thought using the hand brake would
disable them while double parked.
Sometimes when I double park at night waiting to pick up my girl from her job... I want to turn them OFF and still keep the car ON. I know that when you first turn the car ON the lights don't go ON until your start to drive off.
That's why I'm asking...
thanks,
maguirre
00' SR5, 5spd
maguirre is offline
Old 09-28-2005, 01:33 PM   #2 (permalink)
msw0085's Avatar
Send a message via AIM to msw0085
..ahem..
http://www.yotatech.com/search.php?searchid=1098786
__________________
TOYOTA|moving forward
1996 3.4 Litre | 4-Wheel Drive | 5-speed Manual Transmission | Magnaflow Exhaust
Deckplate | Intake Silencer Removal
*MasterDebater*
msw0085 is offline
Old 09-28-2005, 01:37 PM   #3 (permalink)
Send a message via Yahoo to bamachem
a search for "daytime lights disable" gives you this thread:
http://www.yotatech.com/showthread.p...lights+disable
which lists this link:
http://www.yotatech.com/~corey/tech/ducky_drl/ducky.htm
but since you have a '00, then you just:
"uplug (grey plug) the resistor next to the battery (small vented box between the batt and fender). That'll work on an '00"
and is backed up by this statement:
"The plug is to the contraption bolted to the inside driver's side fender by the battery in the '00. The TSB DOES apply to the '00, but it's a lot more trouble than simply unpluging a connector, plus, disabling via the connector is easily reversible. I keep mine plugged in, but I'll unplug it for the drive-in theater, campground, etc., when you don't want your DRL's operable at night."
bamachem is offline
Old 09-28-2005, 02:09 PM   #4 (permalink)
Rick F.'s Avatar
Location: Far western Kentucky (transplanted from central PA)
Send a message via AIM to Rick F. Send a message via Yahoo to Rick F.
Quote:
Originally Posted by bamachem
"The plug is to the contraption bolted to the inside driver's side fender by the battery in the '00. The TSB DOES apply to the '00, but it's a lot more trouble than simply unpluging a connector, plus, disabling via the connector is easily reversible. I keep mine plugged in, but I'll unplug it for the drive-in theater, campground, etc., when you don't want your DRL's operable at night."...
Hey! I said that!!! Well whudya' know...
__________________
'00 SR5, Desert Dune: 4" Deckplate, Amsoil TS-115, Bilsteins, Brembo rotors w/Performance Friction pads, Fiam Highway Blasters, Sylvania Silverstars, Hella Micro DE Fog Lights w/Hella Yellow Star Lamps - SOLD 1/24/09
'08 Sport, Salsa Red: Hella Optilux fogs, Silverstar Ultra Hi beams. Pending: Borla dual catback, CAI, shocks
Rick F. is offline
Old 09-28-2005, 02:23 PM   #5 (permalink)
Guest
4RUNR's Avatar
Good mod for doing a drive-by. Or picking up girlfriends
4RUNR is offline
Old 09-28-2005, 03:46 PM   #6 (permalink)
celica's Avatar
The switch that activates the daytime driving lights is the e-brake switch. When you start the truck the daytime lights won't come on unless the e-brake is released, once they are on they won't turn off if you engage the e-brake until the vehicle is turned off. So to get them off & the engine running you need to engage the ebrake, turn off the truck and restart it, leaving the e-brake on. Then they won't turn on until you release the e-brake
Matt
__________________
Matt
2003 4-Runner Limited - Couldn't stay away from the runner
2003 Sequoia Limited
1989 Supra Turbo
1992 4r, 5spd V6 Sold
celica is offline
Old 01-08-2006, 10:09 AM   #7 (permalink)
maguirre's Avatar
Thank you guys....
The easiest mod so far
maguirre
00' SR5, 5spd
maguirre is offline
Old 10-21-2007, 12:47 PM   #8 (permalink)
2000 4Runner DRL disable:
Disconnect connector D8 PIN 2 (Black/Yellow Stripe) wire.
An inline switch can be installed for manual operation of DRLs.
02Surf SSR-X 4xSport is offline
Tags
2000, 4runner, drl
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
headlight flickers 98runner 95.5-2004 Tacomas & 96-2002 4Runners 8 08-16-2008 05:53 PM
headlight ? 1987 street toy 95.5-2004 Tacomas & 96-2002 4Runners 3 01-14-2005 01:33 PM
headlight DRUMER77 95.5-2004 Tacomas & 96-2002 4Runners 5 06-27-2003 12:46 AM
Which Headlight, One Headlight .) Mossback74 95.5-2004 Tacomas & 96-2002 4Runners 10 02-09-2003 07:10 PM
2009 InternetBrands, Inc.
