Header 22re
Old 05-19-2005, 11:22 AM
Unhappy Header 22re
I have a 89 4runner with the 2.4L 22re 5 speed Manual, and looking into putting a header on it but want to keep the EGR on the exuaust. need to pass emmisons. looking for something cheap but good and will almost just bolt up if you can send me in the right direction would greatly aprecate that
BRAD
Old 05-19-2005, 11:49 AM
sefus's Avatar
a pacesetter from summit is cheap and fits right in, along with being of the same tri-y design as the mucho expensive headers.
Old 05-19-2005, 12:21 PM
Glenn's Avatar
I don't believe the EGR has any connection to the header. It didn't on my truck, which is the same year as your 4Runner. I have a Doug Thorley, better than a Pacesetter (which will rust out), but not as good as a spendy one from LC Engineering.
Old 05-19-2005, 02:43 PM
rugerm44's Avatar
Get ceramic coated one.I sold one that had one on it.Ran it 3 years no problems.They aint cheap but beats buying three.
Old 05-19-2005, 02:59 PM
Thanks i looked it up it is a cheap header now if i get the ok i will buy it thanks again.
Old 05-19-2005, 03:01 PM
truck dont have much more life to it and if it rust out ill just buy a stock mainfold lol i want something performence on my truck lol. thanks for all the helps
Old 05-19-2005, 03:30 PM
bike4miles's Avatar
What do you have to do to install one? Don't you have to trim the pipe back? How much does that cost?
Old 05-19-2005, 03:43 PM
kyle_22r's Avatar
EGR isn't connected to the header -- but the air injection system or whatever is.
Old 05-19-2005, 05:29 PM
Glenn's Avatar
Trim what pipe back? It was strictly bolt on for me.
Old 05-19-2005, 05:42 PM
bike4miles's Avatar
Nice, I thought the header was longer than the stock manafold. If I knew is simply bolted in I would have gotten one a long time ago!
Old 05-19-2005, 05:50 PM
bike4miles's Avatar
I have had my eye on one of these for a while but it says fabrication may be required. For what?
http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
Old 05-19-2005, 07:25 PM
Glenn's Avatar
Some brands may require some fabrication. I don't exactly remember, but I think my header collector pipe was an inch or so off. But it was pretty easy to move things around and make the match. I have had no leaks, either at the header flange, or any of the other connections down from there. It has been on there 5-6 years now. It wasn't too hard to install with the help of a friend.
Oh, and don't be tempted to start your truck with no header "just to see how loud it is."
Old 05-19-2005, 07:51 PM
4Crawler's Avatar
My LC header bolted right up, EGR works (although I needed to do a little porting to get it to pass the stricter CA smog check this year). My '85 uses the block off plates and the internal EGR ports, some years add the EGR plumbing externally in place of the block off plates:
http://www.4crawler.com/4x4/CheapTri....shtml#Exhaust
rednecktoyotahunter
11-18-2015 08:58 AM
RatOmeter
10-22-2015 03:17 PM
Fakayayou
08-09-2015 12:47 AM
clok
08-01-2015 09:42 PM
Dakotaneu
07-27-2015 12:03 AM
Quick Reply: Header 22re
