head gasket or something else?
Old 03-07-2004, 04:29 PM
keisur's Avatar
today on the beltway after going through the toll booth and then accelerating hard up to 70 mph, I had the rear window down and noticed a slight coolant smell. so I thought maybe it got a little warm and purged itself out of the res. well, when I stopped I checked and it hadn't purged from the reservoir. so when I got back on the beltway I noticed it again so I closed the back window and it was gone, which tells me that it wasn't coming from the engine compartment but possibly I was smelling it leaking into the cylinders and burning so then I smelled it coming out the exhaust, which is why I could only smell it with the rear window open. does this make sense? if the head gasket was toast would I smell it in the exhaust?
Old 03-07-2004, 04:43 PM
its2slo's Avatar
yes and your truck would run very rough and youd be losing coolant.
Old 03-07-2004, 05:19 PM
MTL_4runner's Avatar
I 'm not sure if the engine would run crappy with a small leak.
Definately keep and eye on the coolant level and watch it like a hawk.
Old 03-08-2004, 04:23 PM
keisur's Avatar
it's not running crappy but I'll watch the coolant level.
thanks.
Old 03-08-2004, 04:33 PM
juan1225's Avatar
I have almost something like your case but I found smoke under the hood and inside the passenger side I check and I think is a leak from the manifol on the passenger side!! and there is also coolant all around the transmission help please.
Old 03-08-2004, 05:29 PM
keisur's Avatar
the smoke is probably a manifold leak juan. but the coolant around the tranny kind of scares me. I don't think mines leaking that bad if at all. I haven't noticed any level change in my coolant. your's could very well be the head gasket in my opinion.
oh yea, I noticed in your profile you were looking for the "pvc" valve. did you ever find it? if so, could you tell me where it is? hehe, just kidding.
Old 03-08-2004, 07:22 PM
its2slo's Avatar
yes there is an internal and external leak problem on them. check if its recalled juan. if its internal though youll definately know it, so no worries keiser, but pick up a spare 3.4 while theyre still cheap j/k
kgcwb44
01-29-2023 10:02 AM
the1998sr5
15
07-14-2020 08:35 PM
09-04-2015 09:27 AM
themightykhoner
08-11-2015 07:37 PM
Coreyr384
07-10-2015 11:13 AM
Quick Reply: head gasket or something else?
