| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Head Gasket Replacement
#2 (permalink) |
In my research for why Toyota uses Red coolant, and if I can replace with US green/gold when I do the flush following my gasket replacement, I came across this article in Popular Mechanics. Thought it was an interesting read for those wondering about the Toyota Red coolant and any comparable US or cheaper subsitute.
http://www.popularmechanics.com/auto...tml?page=1&c=y |
#3 (permalink) |
Avoid the Felpro gaskets, they're junk. Assuming you have the 3vze 3.0 V6, do a search on it and you'll find everything you need to know. Use factory Toyota headgaskets, Victor Nitroseal head gaskets (found @ Car Quest or Checker? 1 of those 2) or get Enginebuilder's kit with his new head bolts. You have to replace the factory head bolts because they're one time use only! Also, replace water pump, timing belt, noisy belt pulleys, and the knock sensor wire. Make sure your heads aren't warped, valves in good condition, and reset the valve clearances. Better yet, get them rebuilt with a 3 angle valve job for $200-$250. Make sure you have a lot of valve clearance on the exhaust valves, as those burn up quickly with the stock exhaust manifolds/crossover pipe. Get Downey headers if you can afford it. Good luck!
__________________
'92 toyota Xtracab 4x4 pickup-3.0 v6,5 speed, 235/75 15" tires, intake "Y" hose and associated vacuum boxes eliminated,186,000 mi., engine almost together,Engnbldr's grade 10.9 head bolts, clutch now replaced w/Centerforce dual friction clutch. '84 toyota Supra P-type 5MGE inline 6, 5 speed, 179,000 miles, RWD Ltd. slip, Pacesetter header, 5 slot mags and NO muffler. |
#4 (permalink) | ||
Quote:
Quote:
__________________
- Jamie 1996 4Runner SR5 4X4 Auto Deckplate Mod, Hayden Tranny Cooler, Amsoil Air Filter, OME 881/906 N86C/N91SC Lift Best OBD II scan tool I have used!. .....and I am AMERICAN! Last edited by MTL_4runner; 01-24-2006 at 12:50 PM. |
#5 (permalink) |
Ooops! Sorry, I was just a little too anxious to help I guess! Some of it might apply, though. It should be TONS easier than a V6! Good luck!
__________________
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| ? found during head gasket replacement | ELD | 86-95 Trucks & 4Runners | 6 | 02-10-2008 10:03 PM |
| head gasket replacement | AKripper | 86-95 Trucks & 4Runners | 4 | 08-25-2006 07:48 AM |
| head gasket replacement | clint | 86-95 Trucks & 4Runners | 15 | 07-11-2006 02:46 PM |
| Head Gasket replacement procedure ? | Foch | Maintenance & Repair Archives | 1 | 05-20-2004 04:59 PM |
