head gasket? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 03-25-2005, 04:10 PM   #1 (permalink)
head gasket?
I was driving my 89 toyota and noticed alot of steam coming from the exhaust even after it warmed up it. Then it started overheating I was almost home so I just stopped let it cool then drove home before it could get hot again. I checked the oil and it was clean on the dipstick no signs of water but had milky sludge on the oil cap so figured it was a blown head gasket. It has been sitting for a few weeks and I checked it out today and noticed there is now alot of water in the oil so it leaked into the oil just from sitting.
Does this sound like a head gasket or cracked head? I was hoping to just replace the head gasket and get it back on the road. Its a 89 toyota pickup with a 22re and 153k miles. It was using a coolant before this but only being a bit low about every 5000 miles.
John79 is offline
Old 03-25-2005, 04:22 PM   #2 (permalink)
jimbo74's Avatar
Send a message via AIM to jimbo74
sounds liek a head gasket... could be a cracked head though...... the only way to find out is to take it apart..... get the head checked out, if its good have a machine shop do a valve job and resurface the head, then get a new head gasket and your good to go, will also want to replace the head bolts with studs if you have never attempted this kind of thing before, on some engines the head bolts are reuseable, but its best to get a new set
jimbo74 is offline
Old 03-25-2005, 06:33 PM   #3 (permalink)
Is it really necessary to have the head resurfaced? I was planning on just getting the parts and trying to do the whole thing in a weekend. I guess it would be a good idea to get the best fit. I'll have to pull the head first and make sure its ok.
John79 is offline
Old 03-25-2005, 07:22 PM   #4 (permalink)
PirateFins's Avatar
Send a message via AIM to PirateFins Send a message via Yahoo to PirateFins
I would pull the head and take it to an automotive machine shop. Have them pressure test it and test the flatness. That will find out if it is cracked and if it needs to be machined.
Try and disonnect everything leaving the intake manifold and runner attached. This makes it easier to remove and disassemble on the bench. Carefull of the knock sensor wire (that was a $120 mistake I just made). If the head is cracked look into getting a replacement from engnbldr.com (Ted is a member here andis good people).
__________________
Brad
Work is for those who don't know how to plunder!!
Quote:
Originally Posted by habanero View Post
I'd experience an O so big it'd show up on the richter scale.
92x-cab dlx 4x4 22RE, Pacesetter header, everything else is so stock it's not funny, cause I don't have the money!
04 F150 FX4 SuperCrew
PirateFins is offline
Old 03-26-2005, 06:03 AM   #5 (permalink)
netwt12's Avatar
take the head to the machine shop if for no other reason but to determine if it is warped. they can also pressure check it for cracks and clean it up. if you are going to go through the trouble of pulling the head don't skimp and do the job half way.
__________________
1985 X-cab pickup. stock
1988 Trail Truck. SAS, Dual Cases, FROR Twin stick, 30 Spline Longs & IFS Hub Gears, Exoed, Aluminum Trail-Ready Beadlocks, 37" Boggers, and Extreme Rock Rash.
2008 Camry LE.
netwt12 is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Head gasket? Kaydon 86-95 Trucks & 4Runners 12 06-16-2007 02:01 PM
3.0 head gasket callmej75 95.5-2004 Tacomas & 96-2002 4Runners 32 08-21-2005 12:37 PM
Cracked Head or Blown Head Gasket? StevenR Maintenance & Repair Archives 5 06-14-2005 10:49 AM
Is My Head Gasket Going! Help! Ilovemountains 95.5-2004 Tacomas & 96-2002 4Runners 4 01-21-2005 02:37 PM
Replaced Head Gasket, but not Head Bolts -- How bad is this? The Rusty Gear 95.5-2004 Tacomas & 96-2002 4Runners 14 09-13-2004 08:03 AM
2009 InternetBrands, Inc.
