head cleaning
Old 03-05-2004, 02:28 PM
joe d95's Avatar
head cleaning
What is the best way to clean aluminum heads?
Old 03-05-2004, 03:53 PM
MTL_4runner's Avatar
Are they still on the engine or are you rebuilding them?
Old 03-05-2004, 04:01 PM
Take them to a machine shop.
Old 03-06-2004, 05:21 AM
934rnr's Avatar
Lots of carb cleaner about 5 cans a tooth brush and a green scuff pad for the headmounting surface. Or if you feel like spending big bucks take it to a machine shop. Resurfacing heads isn't always necessary sometimes they take too much material off and you play hell trying to get your vehicle running right again. If you check the surface of the heads with a flat ruler make sure it's not warped you can get away with cleaning it and using a scotch pad on it.
Old 03-06-2004, 05:32 AM
If they are ff the truck, just have them acid dipped.
They will be as clean as they were from the factory.
jasonty
41
12-23-2018 01:00 PM
09-04-2015 09:27 AM
whereAreMyPants
07-22-2015 03:32 AM
yourrealdad
07-21-2015 11:13 AM
87blyota
07-10-2015 04:31 AM
Quick Reply: head cleaning
