Have you found your intake kit worth the money?
Old 03-30-2005, 03:13 PM
baileymoto's Avatar
About to replace my filter and I was probably just going to buy a K&N replacement filter (so I can wash it when needed).
I am however, considering a full replacement cold ait kit (probably K&N). Have you found yours really worth the money? I imagine performance gains cant be of all that much, but how did your gas mileage increase, if at all?
Also, this would be going on a 1999 2.7 4x4
thanks
Old 03-30-2005, 03:31 PM
bike4miles's Avatar
I used the K&N drop in for a while and it was the biggest waste of $50 ever. My new setup cost me about $40. I installed a cheep cone filter from ebay and fabed a custom heat shield that offers WAY more coverage than any kit. Big diference in thotle response and a bit more hp overall. Well worth the time and money.
Old 03-30-2005, 04:34 PM
96LtdYota's Avatar
YES... the deckplate mod.... search and you shall obtain boatloads of info on this
Old 03-30-2005, 05:43 PM
gwhayduke's Avatar
Skip K&N. Increased air flow means increased dust flow. A mining company tested K&N vs. stock and found increased silica (sand) in the oil after the change.
Of course, maybe you like polishing your cylinder bores with silica...
Old 03-30-2005, 05:48 PM
SD70MAC's Avatar
What if you use the K&N prefilter? It supposedly filters out very fine particles and repels water. I use a K&N filter and Outerwears prefilter on my ATV and have never had a problem with either dust or water getting in there.
Old 03-30-2005, 06:16 PM
hamstrungtaco's Avatar
go with the amsoil and the deckplate, i have the fipk and it collects dust overtime, not to mention the heat shield screw put a tear in my wheel well, im going to go back to stock eventually when i set the time
Old 03-30-2005, 07:01 PM
Ehinfinity's Avatar
I had the Injen model air intake, took it off about 6 months ago and went with the amsoil filter and deckplate mod, best change I have made to date. Less noise and more water protection.
Eric
Old 03-30-2005, 07:13 PM
Yamaha+Toyota=Fun's Avatar
Build ur own!! I swapped my battery and my airbox, put a deckplate in. Instant HP. I still use a stock filter, keep everything out that needs to be out.
Old 03-30-2005, 07:18 PM
Chapman88SR5's Avatar
[QUOTE=Yamaha+Toyota=Fun]Build ur own!! I swapped my battery and my airbox, put a deckplate in. Instant HP. I still use a stock filter, keep everything out that needs to be out.
QUOTE]
agreed, i did basically the same thing and didnt pay a dime
Old 03-30-2005, 07:26 PM
LS1Steve's Avatar
I would like mine to breath better, but am not about to drop $150 for the k&n fipk, so I am getting a cone filter + MAF intake adapter on ebay for $9 +shipping, brand new.Then I will just look for a 3" aluminum pipe from some ricer shop with the right bend to replace the connection behind the MAF to the throttle body and get rid of the silencers.
Old 03-30-2005, 08:00 PM
anestech*'s Avatar
I like my $69 shipped eBay ricer intake. Basically a ripoff of the Airaid system. Sounds good, and has noticeably increased power. Fittement was so-so, and it took some fiddling, but otherwise quality it very good.
Old 03-30-2005, 08:11 PM
LS1Steve's Avatar
a fellow LS1'er!! Nice to see on here!!
Old 03-31-2005, 08:22 AM
Vtec_Killer's Avatar
I want to get an intake for my 2nd gen, but will probably end up getting a snorkel. Diving into little puddles...me likey.
Old 03-31-2005, 09:15 AM
Keggo's Avatar
I'm trying to figure out a way to set up a snorkel and have it open all the time with the stock airbox having an on/off setup on it... it's just that damn MAF sensor... I have to figure out how to keep that thing going if I close up the stock airbox.
Old 03-31-2005, 09:34 AM
anestech*'s Avatar
w00t!
Old 03-31-2005, 10:07 AM
2000t4r's Avatar
I found that removing the elbow was worth it I did notice a difference around 2-3,500 RPM range. I have the K&N filter
Old 03-31-2005, 10:21 AM
v8sport4runner's Avatar
I just took my k&n air charger off my runner. It was loud towing up the mountains and I just got tired of the noise it made. I actually think i have more power now tho. When i put it on i lost a bit of low to mid range kick. It didnt really do anything for me the time i had it on, no HP increase or MPG increase. I'd say they are not really worth it IMO.
Old 03-31-2005, 10:59 AM
MotaPsycho's Avatar
Anyone install a Volant cold air intake kit? those thing go for bout 3 benjamins... but they do give you a lot more protection.. is it worth 300 bucks?
bigjstang
08-25-2021 12:41 AM
XtraCab
04-12-2020 05:25 AM
jerusry
10-19-2015 05:28 PM
09-04-2015 09:27 AM
skoti89
07-08-2015 12:05 AM
Quick Reply: Have you found your intake kit worth the money?
