Have y'all seen these joints?
http://www.daystarweb.com/cgi-bin/lookup
Depending on price, I might pick up a few and see what I can do with them.
Unfortunately, the site isn't very detailed. I have tried different ways to make the link work, but for whatever reason, it just kicks you to that first page. Put in all your vehicle info, then select the Poly(heim) joint from the product list.
Looks like the Rubicon Express "Johnny joint", which you can also purchase from www.spidertrax.com
I've never seen a decent drawing of width requirements, though. I had only heard the 2.625" minimum. Stock 3rd gen 4Runner rear mounts are slightly narrower than that.
Originally posted by Cebby
Is that a spherical joint with replaceable inners? What is the material inside it - UHMW Plastic? The link doesn't take us to that item...
http://www.wps.on.ca/technical/html/...lyethylene.htm
This stuff is used all the time to replace things like bronze bushings. It' wears longer and is self lubricating...
kawazx636
10-06-2021 03:03 PM
FS[MidWest]: 1.5" ball joint spacers
4x4YOTA
08-23-2016 09:08 AM
FS[SouthCent]: TX - 4Crawler Ball Joint spacers
crash813
09-27-2015 07:15 AM
Odin
09-26-2015 06:56 PM
