have poping in front end
Old 11-12-2011, 06:08 PM
yota runner sport's Avatar
Need help i own a 2002 4runner sport with a 2.5 inch daystar lift and here recently i have a poping in my front driver side suspension area. it usually does it worse on rougher parts of road and terrain. Is it a cv axle going out or maybe a shock
Old 11-12-2011, 06:39 PM
J2F42C's Avatar
Yep, CV more than likely. A remanufactured OEM or rebuilt one is your best bet. If using a new one from the big box stores, Napa works.
Old 11-13-2011, 06:34 AM
how hard is cv to put in?
Old 11-22-2011, 02:19 PM
TheeMikeB's Avatar
Not hard at all, I used this write up as a general guide and I was able to do mine by myself in a couple of hours. That's with the first time 'learning curve' If I had to do it again i'm sure I could do it in half the time.
Also you should make sure that everything is tight on the spring and coil, is the daystar lift compressed within the coil/spring pack or is is just a spacer placed on top of the existing coil/spring? If it's compressed within the spring you need to make sure it was compressed properly and the nut on the shock/topspacer is properly tightened. Any slack in here could be causing the pop.
Old 11-22-2011, 05:22 PM
J2F42C's Avatar
Here you go for a link that shows it all:
http://www.4x4wire.com/toyota/maintenance/cv_axle/
I went with the MasterPro from Oreilys only because I had a credit there. I would like to have gone with the NAPA, but it was a good $45 dollars more. Plus I did not have to swap any pieces over from the old CV to the new. And there was no core charge.
Flying91
45
04-11-2024 04:39 PM
jasonty
41
12-23-2018 01:00 PM
09-04-2015 09:27 AM
Daneums
08-20-2015 05:36 AM
88sasturbotoy
08-11-2015 01:56 AM
Quick Reply: have poping in front end
