Has anyone Experienced this?
Old 08-11-2008, 12:14 PM
ariel's Avatar
I need some help.
I have a 96 4runner 2wd, with ignition issues.
Sporadically, I can attempt to start the engine and one of three things might happen.
1 - Nothing. Internal lights radio all come on, but vehicle doesn't start.
2 - Half start. I'll get a engine turn, but then it'll die.
3 - Normal start.
Like I said this is sporadic. I have gotten all three in the order listed, but most of the time it'll be either scenario 1 or 2, and then on a second attempt to start, the engine will start normally.
The engine check light is not on, and when I checked for error codes everything shows ok.
I went to the dealer and they said I needed a Mass Air Flow Meter, not the sensor, the whole assembly.
But I have to admit I'm questioning. I don't know how that's tied to my initial ignition.
I haven't experienced any issues after the car has started (idling issues, driving performance, etc..).
So I'm reaching out.
Has anyone Experienced this, or can give some insight on what the issue might be?
Thxs https://www.yotatech.com/forums/imag...s/banghead.gif
Old 08-15-2008, 05:16 PM
Ron Helmuth's Avatar
sounds like the starter contacts. Search by key words starter contacts as this happens on a lot of the 3rd gens. Likely you will not need a whole starter just a repair of the contacts.
calderp
11-16-2015 02:49 AM
SpookyMulder
11-04-2015 11:56 AM
Rerun
3.4 Swaps
10-01-2015 12:24 PM
Odin
09-26-2015 06:56 PM
eggens
09-05-2015 12:16 AM
Quick Reply: Has anyone Experienced this?
