Harsh ride on my 4runner
On my 98 2WD SR5 I was wondering if all these 4runners ride rough or is it time to replace the struts and shocks? My 4runner rides like a truck. when you hit a bump its like you feel it in your back. any feedback on this would be great. Thanks.
Some more info would be great, like asked above.
Also, check your tire pressure - I was amazed at how much 2psi made.
Do the chalk test and make sure you're running the lowest pressure possible while still maintaining good tread contact.
Fink
Fink
Have you done the bounce test?
Fink
Is the front suspension on these suck, in general? I like the ride comfort of 2003+ 4runner. It rides very well.
Anybody recommend a setup that has a soft suspension(front) like the 2003+ 4runner? Does the shock/spring from 2003+ fit into our generation?
Are there any bilstein comes from tacoma, 4runner, tundra that fits and work well on our 4runner?
thanks.
thanks.
Do you ever plan on lifting it down the road?
I ran stock-height Bilsteins on my 4Runner for a while and they were great.
Stiff enough for moderate off-roading yet soft enough for daily use - still stiffer than stock though so it was a tad bit bouncy.
Also be sure to search on this as it's been somewhat beat to do death.
Fink
Fink
Dont forget--3rd gen was about the last year the 4runner wasnt over "soccer-momed". So that stiff suspension is there partially for a reason.
HOWEVER--Edlebrock makes some great shocks that are smooth at first and then stiffen as terrian gets rougher. IAS is what i run in the rear and i like them.
And you might also want to think about springing light and shocking hard. it will make the ride smoother........
Flying91
45
04-11-2024 04:39 PM
FS[PacNorWest]: 1987 Toyota 4Runner $1800 Whidbey Island, WA
coreyedwards7611
01-16-2016 06:38 PM
BeMiceElf
10-10-2015 09:40 PM
