Is it hard to convert from a carb engine to a fuel injection engine? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 08-10-2003, 02:56 PM   #1 (permalink)
Send a message via AIM to Dodgef150
Is it difficult to convert from 22r to 22rTE with turbo?
Dodgef150 is offline
Old 08-10-2003, 06:14 PM   #2 (permalink)
kyle_22r's Avatar
personally i wouldn't even bother converting. just slap a pair of weber 45mm dcoe carbs on it, a performance cam, and upgrade the exhaust if it was a carbed engine
the 22rte is a lot different from a stock 22r. you would need new forged pistons, new head, turbo, fuel injection system and of course all of the wiring(yech) and ecu that goes with it
if you converted, the smartest way to go would be to buy a whole engine or long block that's set up for a turbocharger
__________________
1998 tacoma, 3RZ-FE, 5 speed, 30x9.5R15 M/Ts
past toys:
1984 4x2
1979 4x4
1991 4x4
kyle_22r is offline
Old 08-10-2003, 06:19 PM   #3 (permalink)
Plays_with_Toys's Avatar
I think the turbos are pretty rare as well.
Kyle, the weber carbs are good carbs then? I looked at them in the smaller configurations when I was going to replace my carb, but was afraid of emissions, and being able to put it in right, with all the vacuum lines coming off the original carb.
__________________
1987 Xtra Cab (4x4) - (SOLD) 22r, Rancho RS 5000, 15x8 American Racing AR-23s w/ 31x10.5 BFGoodrich A/T's, 2.25" exhaust w/ 23 1/8" glasspack, Explorer Pro Comp Prerunner bar/ Hella 500's
Plays_with_Toys is offline
Old 08-10-2003, 08:36 PM   #4 (permalink)
flecker's Avatar
Location: White Mountains, Arizona (Yes it does snow in AZ)
Weber's are the best! I have two on my Baja Bug mounted on a Corvair 6 cyl. It flies! 120 h.p. and plenty left on the throttle. They are fairly simple to dial in and synchronize. Not nessacarily plug and play though! Had to add/ remove a few things. Definately worth it though.
__________________
Rigs: Way to many over the years to list.
Current ones are- 1988 xtra cab, 84 beater.... more to come I am sure.
If you can't dazzle em' with your brilliance... just baffle em' with your bull
flecker is offline
Old 08-10-2003, 09:14 PM   #5 (permalink)
kyle_22r's Avatar
i have a 32/36 progressive on my truck, came with it so i don't know how it would compare to a stock 20R carb, but it supposedly gives you the best of both worlds between horsepower and economy. when you're driving normally, only the 32mm primary is open, but when you punch it, the 36mm secondary kicks in. it's nice to be driving down the road at a typical pace then punching the gas and hearing that nice throaty full throttle sound. the carb is louder than my exhaust or my engine in general when i'm idling
my only concern about emissions junk would be if they check all stuff on your engine. i looked at the 20R stock vacuum diagram and it looked like a nightmare compared to the way it looks with a weber. never knew much about that kind of thing, since they don't smog us at all here. i believe the 32/36 is cal exempt
for a typical replacement carb i'd say go with a 32/36, best bang for your buck. if you want more power and mod your engine more, a 38mm synchronous would be better. finally, if you want to really haul ass and have some really nice mid to high rpm horsepower i'd look into a 40 or 45 DCOE setup. i'd love to run those dual side drafts but they get a bit pricey, but it's sure easier and cheaper than going to a turbo setup
__________________
past toys:
1984 4x2
1979 4x4
1991 4x4
kyle_22r is offline
Old 08-12-2003, 01:28 AM   #6 (permalink)
i am going to put in a new racing 22rte with turbo with all forged parts. i was just wondering if it would be hard to find the intake pipes? What is better Haltech E6K Engine Management System or a stock 22rte ecu computer?
Tags
07, 78, car, carb, carburator, carburetion, carburetor, convert, converting, efi, engine, fuel, hard, injection, sbc, turning
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
When does a 22r carb engine red-line? brendonv 95.5-2004 Tacomas & 96-2002 4Runners 7 01-19-2009 03:16 PM
3.0 engine install?? how hard? kennasbimmer Newbie Tech Section 11 11-21-2006 01:52 PM
Big Lifts...Is it to hard on the v6 engine? jokerswild 95.5-2004 Tacomas & 96-2002 4Runners 8 07-24-2004 12:36 PM
weber carb of fuel injection? playboy 95.5-2004 Tacomas & 96-2002 4Runners 9 01-04-2004 05:42 PM
can you carb the 3.0 engine ? duanedeidre 95.5-2004 Tacomas & 96-2002 4Runners 8 11-05-2003 12:24 PM
2009 InternetBrands, Inc.
