handful of codes, how bad are they?
so i just had to replace the bulb that illuminates the ac controls, and my cel light was on, but usually its been the 02 sensor, which is good, there is just some issue that toyota cannot workout but says if 02 code pops up, dont worry about it. well....i got 4 more codes pulled today while i was at advance auto, and i need to know how serious of a problem they are, and if i need to get them (mostly sensors) replaced:
P0100 Mass Air Flow
P0120 TPS/Pedal Position Sensor A
P0136 02 sensor Bank 1 Sensor 2, (i think its ok)
P0340 Camshaft Position Sensor A-Bank 1
P1300 Manfacurer Contrl. Ignition System or Misfire
thanks for any help
P0100 Mass Air Flow
thanks for any help
if you had all those codes your truck would not be running...
Have you unplugged the ecu before?
Has anyone worked on the vehicle recently? (removing any major parts of the truck and put it back together)
Personally i would clear the codes and drive around to seee if they all come back then figure things out. WHo said a o2 code was ok? Why would it be ok? Sigh...toyota techs really make me wonder sometimes...
well....basically the 02 sensor and cel light was "fixed" by toyota, when they replaced both cat converters (cal spec truck), it came back on about 10 miles down the road, cel light did, and it was 02 sensor...so yea....
i cleared the codes....drove about 50 miles tonight....no light
4wheelparts just installed a new front left cv axle...could that have done it? it was on before they touched it though....
im thinking im ok for now...?
I will never rule out ecu...who knows if the thing will flip out and send codes...the fact that they replaced the o2 sensor and the code came back with everything being ok just means the ecu itself is faulty...everything may be running fine but the ecu just may not realize its outputting all those codes...just drive around and when the light comes back (if) check it again to see what it is.
sounds good, preciate the help. im wondering what toyota did to my ecu when they installed the 7th injector kit...maybe they did nothing but good things
jasonty
41
12-23-2018 01:00 PM
